Old 02-23-2006, 07:14 PM
Justin2380 Justin2380 is offline
97 grand am fuel filter question?
Hey, 1st time here, hope I explain this correctly. Here's the deal, my 97 Grand Am GT is starting rough. When I go to start it, it doesn't start right away when I turn the key over, you know it takes like 2 seconds, it is hard to explain. But sometimes when it starts, it acts like it wants to die, you know like the rpms will go between 0 and 1. Earlier today I coudln't take off right away, becuase it was doing this and couldn't give it gas. So anyways it is a 3100 Engine. And I think all I have to do is replace the fuel filter. Does that sound correct. My problem is though that I do not know where this is, or even how to do it. I have thought about replacing the spark plugs, I pulled one out and it looked ok, I think they are platnum. There is about 96,000 miles on the car. Mostly interstate. So if you could please help me out...thanks!!!
Old 02-23-2006, 09:22 PM
Amerikaner83 Amerikaner83 is offline
Re: 97 grand am fuel filter question?
The same thing happened to my Honda. Not sure right now, but I think if you get a Chilton's or Haynes repair manual, it will tell you all about the fuel filter and what not.
Sidenote: I had to replace my fuel Pump as well, as i let my car run low on gas too many times - if you've done this, a nes fuel pump might be a good idea as well. I believe both the pump AND the filter are in your gas ank, which of course, you'd have to drain to gain access to.
Hope this helps at all:
Michael - Seattle, WA
