Go Back   Automotive Forums Car Chat > Coffee Break (Off-Topic) > Stress Release
Stress Release Warning: Don't get offended by what's in here.
Old 02-23-2006, 07:13 PM
directory's Avatar
directory directory is offline
how do you remove tranmission fluid...
...from your driveway?
some moron sprung a leak (a very bad leak) from the transmission, and decided to pull into my driveway to inspect it.
so i come home, and now there is a huge puddle of fluid in my driveway. not from any of my cars.
like the idiot couldn't just stop on the side of the street...no
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 02-23-2006, 07:20 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: how do you remove tranmission fluid...
that sucks! I hate ass holes with no common sense
Old 02-23-2006, 07:24 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
What's your driveway? Asphalt? Concrete?
My Mopars
Old 02-23-2006, 07:45 PM
cody_e cody_e is offline
Send a message via AIM to cody_e Send a message via MSN to cody_e Send a message via Yahoo to cody_e
Try oil dry to get rid of the wet stuff and gas works as a good solevant to get rid of the stains.
Old 02-23-2006, 11:50 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
dude, go to the pool store and get some shit called Cyanuric Acid. You use it to balance the pH in a pool. You can also use it to get oil off the driveway.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 02-24-2006, 12:00 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
kitty litter! lol, or speedy dry. thats what id do for the bulk of it. after that idk... what about that degreaser stuff for engines?
Old 02-24-2006, 04:50 AM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
I used some heavy duty degreser...but it didnt fully remove the stains.
Yah, try acids...just be carefull, and use LOTS of water when your done. Dont want to kill the Ecosystem thanks to you fixing some assholes mistake.
Umm....gas is worth a try too, but....dont do them all at the same time...all 3 combined might summon the devil or something.
My new RHD project!
Solid Crew (Circa 2002)
Old 02-24-2006, 07:20 AM
nissan_240sx nissan_240sx is offline
First soak up the excess fluid, then use gas, let it sit and hose it down. Try clorox lol. Thats what I use
lol
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 02-24-2006, 06:45 PM
EnergyForce EnergyForce is offline
Combinging all 3 probably wont do that but it might explode im assuming the ph balancer stuff is a base, base + acid = water + heat + some kind of gas possibly
+ regular gas that you put in your car will probably = boom.
Old 02-24-2006, 06:46 PM
your wrong. Sorry...the gods told me so. It will summon DEVIL!
Welcome, TerminalVelocity.
You last visited: 02-24-2006 at 02:51 AM
Private Messages: Unread 0, Total 666.
see, im the devil agrees!
(saw I had 666 and had to say something about it somewhere )
My new RHD project!
Old 02-24-2006, 08:16 PM
Andydg Andydg is offline
Diesel or kerosene should work but if not try some driveway cleaner they have at Menards it's got some sort of acid in it that works pretty well.
*Edit* Brake cleaner may work also.
Old 02-24-2006, 08:59 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Do NOT use any petroleum product (diesel, gas, solvents) on an asphalt driveway. The asphalt will soften and be damaged and discoloured.
As noted above, use oil dry or kittly litter on the spot for a couple of days. Grind the absorbant into the stained area with your foot.
If its concrete, brake cleaner and a brush will remove any stain.
If its asphalt, your driveway is stained for good, but time and the weather will reduce the stain somewhat.
Old 02-25-2006, 06:45 AM
mwrobe1's Avatar
mwrobe1 mwrobe1 is offline
Hmmm...never knew that...
Elwood: It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it.
2013 Chrysler Town & Country Touring
2013 Chevy Impala
2006 Kia Rio LX 80k [SOLD]
1997 Plymouth Voyager 2.4L 180k (headgasket at 75k/tranny at 65k) [SOLD]
Old 02-25-2006, 09:30 PM
directory's Avatar
concrete
SKYWARN
we be clubbin'
--B
