Old 02-23-2006, 06:34 PM
nerij nerij is offline
Engine service is ON
Hello Pals
The “engine service soon” of my Astro 96 turn on, I pull out the codes, but not sure what the problem might be
The codes are
P0172B
P0175B
And there was another one that I was not available to write it down, but according to the page
http://autorepair.about.com/cs/troubleshooting/l/bl_obd_main.htm
code
P0172B means System too Rich (Bank 1)
P0175B means System too Rich (Bank 2)
Any thoughts or advise of what this really means.
All information you will be available to provide will be highly appreciated.
Regards,
Old 02-23-2006, 06:41 PM
maxwedge maxwedge is offline
A990 racer
Re: Engine service is ON
How does it run/start other than the codes?
Old 02-23-2006, 06:52 PM
Maxwedge
Thanks for getting interesting on this!
It starts and runs just fine and it seems not to be a problem when I’m driving, “the only problem” it’s that light “ON” of the service engine
Old 02-23-2006, 07:30 PM
dewaynep dewaynep is offline
I would imagine, if it really is running rich, you will notice a drop in mileage. It may help to find out what the other code was. Since it is showing running rich in both banks I think you may be able to rule out the oxygen sensors. What could it be: stuck injectors (would have to be at least 2 on seperate banks, not likely), could be fuel pressure regulator that is stuck and not allowing excess fuel pressure to run back to the fuel tank, could be as simple as a dirty air filter or bad plugs or ignition. Could be a lot of things, but without covering the basics first can't say for sure. One thing is for sure, if it is running rich your catalytic converter will not last long.
Old 02-23-2006, 07:46 PM
Well I think that catalytic converter will be a no cheap repair, in fact there are no cheap repairs, but I will like to avoid any problem on the road so, I will work on the other issues you mention to see what I can find
I really appreciate you help on this,
Old 02-23-2006, 08:58 PM
Kings-x59 Kings-x59 is offline
unless the codes were cleared, the third code should still be stored.
I'd try to get that code. It may shead some light on the problem.
That third code might show a fault in the mass air flow sensor.
Or, you might have a leaking injector.
'89 Astro 4.3L Z
CFM-Tech power plate
2.5" exhaust, Low restriction cat and muffler
Jet stage I chip
B&M trans cooler
'96 Jeep Cherokee
'99 Chevy Cavalier
