Old 02-23-2006, 07:17 PM
carguyvr4 carguyvr4 is offline
Send a message via AIM to carguyvr4
battery light?
ok so i replaced my battery recently and everything is tight on it but everytime i make a right hand turn or anything like it the battery like flickers.... now i tryed having some one watch for the batter light to flash while i move the battery around and what not but nothing happened i was woundering if it could possibly be the alternator and everytime i make the right hand turn it puts strain on it and the vlotage drops is.. does this sound familar to anyone ?
Old 02-23-2006, 08:31 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: battery light?
Ok the battary flickers explain like gauges/headlight dim or its like u loose power totaly? I know if you alternator is up to par and hit the breaks and the guages etc dim that is alt. But if a full on loss double check those cables. Only right turns could it be fuel pickup issue i know in the maro if i hang a curve really tight on lower fuel it would somthign simular b/c the fuel pickup.
Old 02-23-2006, 08:48 PM
AutostradaVR4 AutostradaVR4 is offline
Re: battery light?
do you lose power? or does the light just flicker...
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-24-2006, 12:00 PM
2old 2old is offline
Re: battery light?
I hate to sound like a idiot but I saw a light that I thought was a bettery light that gave the same symptoms as well.
I spend a few days trying to figure out what was wrong when I finally broke down and looked up the light it turned out it was the coolant light (which looks more like a battery then a radiator).
But that is jsut me.
Old 02-24-2006, 02:54 PM
Re: battery light?
the light is like the third or fourth one down from the right side guage lights.... yea my headlights do flicker somewhat when the idle goes up or down but i dont loose power it jsut flickers while i turn my steering wheel like a quarter turn to the right but it only does it while driving not if i jstu turn the wheel stoped....it also does it durring some bumps but i dont loose power it jstu flickers its really puzzleing cuz i checked my battery connections and they are all tight i even pushed the battery around and the light didnt flicker?
Old 02-24-2006, 03:33 PM
Igovert500's Avatar
blue + red light magnet
Re: battery light?
I'm with 2old, double check the manual and make sure it is the battery light. Because I once had issues with thinking the coolant light was a wiper fluid light. Always best to double check first.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-25-2006, 11:00 AM
Re: battery light?
i put coolant in the thing it wasnt that low but a lil and the light still coems on so idk and i dont have the manual for the car the guy i bought it from didnt have it
Old 02-27-2006, 01:28 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: battery light?
i think i know the problem. the light that is flickering ONLY when you turn your car while moving is the WINDSHIELD WASHER RESERVOIR light. it just means that you're low on washer fluid. the same exact thing has happended to me many a time: only when turning while moving does this same light flicker.
here is a diagram of all the indicator lights. the one in question is #27. hope this helps, sorry the picture is fuzzy.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
