Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-23-2006, 03:32 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
97 JGC Auto trans problems
We have recently had some trans issues w/ our 97 JGC;
- on occasion, the 2-3 shift does not occur unless u let off the gas, then get back on it.
- while sitting at a light, the trans feels like it wants to pop out of drive and the truck will shake a bit. putting the trans in neutral makes this stop. put it back into drive and give it some gas and its ok. this has only occured once or twice.
Both of these problems occur when the engine is cold and when fully up to temp. The truck has 130,*** miles on it and we have not performed any trans service since we have owned it other then topping off the fluid every once and a while. We will do a trans fluid change soon but any suggestions would be greatly appriciated. thank u in advance.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 02-24-2006, 02:02 PM
legalfee legalfee is offline
Re: 97 JGC Auto trans problems
I'd advise getting a power flush and fill of transmission fluid and also a band ajustment. SJ
1984 AMC Wagoneer Limited (RIP - Burned)
1996 Chrysler Grand Cherokee Limited (for sale)
1999 Chrysler Sebring Convertible JXi
2004 BMW X3
Old 02-24-2006, 09:01 PM
trannyman52 trannyman52 is offline
Talking Re: 97 JGC Auto trans problems
Don't ya luv free advice!!!!! Here's some more,,,,, the first problem "could" be a TV Valve adjustment,,,,,second could be a filter issue "plugged"
A "super flush" will change the oil,,,,,,,,the filter WILL STILL be plugged. The reason the flush is pushed is they do not open the trans,,,thus cannot possibly introduce contaiminents into the system,,,,which leads to "It never did that before" ::er:: FREE TRANNY JOB!!!! What YOU got was some new oil,,,AND your wallet is lighter and the trans problem,,,,,,STILL THERE,,HMMMMM
Take it to a tranny shop usually will see ATRA member or ATSG member,,,
Have them do a fluid & filter service,,,,When the pan is removed you can see how much trash is in the bottom ,,,,,which will determine what REALLY should be done................
??????????When they do a "super flush",,,,, Do they fill it with"super oil"???????
Thing green,,,go yellow....E85
