Old 02-23-2006, 02:50 PM
gtorick gtorick is offline
MPG...what happened??
I have a 92 Metro 3 cyl, i have always gotten 45-48 mpg without the A/C. Now, i'm getting 33 mpg....still runs good, doesn't seem to miss or anything. I did try to idle it up as it was dying at stops with the a/c on.Any ideas?
Thanks!
Old 02-23-2006, 02:55 PM
geozukigti geozukigti is offline
Re: MPG...what happened??
Well that depends. When did you notice the MPG loss? Usually by the winter, gas companies add MTBE to the fuel to keep it from freezing. Adding alcohol will kill your MPG. Also, cold air will cause your engine to run more rich, because of the air intake temp sensor.
Old 02-23-2006, 03:21 PM
I'm in Texas and the mpg went down last summer.
As far as the mpg problem goes, i have found a couple threads that address this problem. Thanks!
