Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-23-2006, 02:08 PM
geobass geobass is offline
Thumbs down 1993 Ignition linkage
How bad of a job is it? Loks like the only way to replace it is to romove the steering wheel? Any pointers would be appreciated...
TIA
Geobass
Old 02-23-2006, 08:57 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: 1993 Ignition linkage
what problems are you having?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 02-24-2006, 11:38 AM
The car will not shut off. I believe the link pin broke on the bar that goes from the ignition cylinder to the electrical switch. I had to remove the electrical connector to get the motor to stop.
Thanks
Old 02-24-2006, 01:04 PM
so your talking about the part where the key gos in if so thats your ignition switch or key and tumbler and its farly easy to replace just call up a ford dealer and give them your vin tell them you need a ignition key and tumbler keyed to your vin and they should be able to get you one then when you get the new part take the old key and put it in the old ignition and turn it to the run position and look directly under it you will see a hole in the plastic that wraps around the steering colum push a metal punchup in there and pull the ignition out then slide the new one in and that should fix ur problem hope this helps and good luck
Old 02-24-2006, 02:50 PM
raymerc raymerc is offline
I had the same thing happen last summer. you can use car in emergency,but will have to diconnect battery each time. You have to pull whole steering column if pin came out. Doable but complex with tilt steering. Will have to seperate steering column after removal.No parts were broken on mine just retreived pin and replaced. Very labor intensive.
Old 02-24-2006, 10:18 PM
What a nightmare!!! Six hours without a break to complete. Pin had come loose from the bar. $8.92 in parts and a migraine headache.
Thanks
