Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-23-2006, 01:26 PM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
Trys to stall when warn start
Guys,
Bless you all for this forum. I haven't been here in a while so I wanted to say that real quick.
The problem I have right now, is when the truck is warm, when I go to restart it from a quick stop the idle bounces for a few seconds and then stabilizes. This never happens when it is cold, only after it is good and warm.
EGR?
IMG?
Thanks for the help!
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 02-23-2006, 01:31 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: Trys to stall when warn start
the bouncing idle sounds like an IMG, that's what mine did. Is the CEL on?
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 02-23-2006, 01:47 PM
highlandlake highlandlake is offline
Fuel injection temp sensor? (If the rodeo even has one, an Oldsmobile I used to have would do the same thing - sensor replaced, problem went away)
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 02-23-2006, 02:57 PM
rodeo02 rodeo02 is offline
I'd check the idle air control valve first (IAC). 1993-1999 3.2/3.5's have them. It's mounted on the side of the throttle body. It's a motorized valve that bypasses air around the throttle plate to maintain idle speed. Often they stick with dirt/carbon. Throttle by wire on 2000+ did away with IAC.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 02-24-2006, 11:07 AM
No CEL, I will take a look at the IAC. I need to clean my EGR anyway, sounds like a good time to do it all at once. I will let you know what I find.
Old 02-24-2006, 11:32 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Try this next time.
turn the key on. count to 10 and then start it.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-27-2006, 04:28 PM
I always wait for the fuel pump to finnish pressurizing the system before I start it, doesn't seem to make a difference in this case. Also only happens after the engine is good and warm. It always stabilizes after a few seconds of reving.
Old 03-23-2006, 01:05 PM
Wow, what a difference a clean EGR can make! Pulled the TB and sure enough the EGR was completely blocked. Cleaned out the tube, scrubbed the TB clean, cleaned the EGR valve. Now she runs perfectly, idle settles very fast, no more reving. As always thanks for the help guys!
