Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 02-23-2006, 11:42 AM
Trooper Noob Trooper Noob is offline
Which PCV Valve for my 2001 trooper Part # ?
I just bought a 2001 Trooper, and had it thoroughly inspected before buying. One of the things needing to be replaced was the PCV Valve. Only problem, is I don't see which one I need. It seems like there were at least 2 different valves used in 2001. Anybody know the part # the need? How can i figure this out?
Here's a link to the website I want to order from, the page with these valves:
http://oem.overnightautoparts.com/pa...0Valve&dp=true
Old 02-23-2006, 12:10 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: Which PCV Valve for my 2001 trooper Part # ?
I am not sure which one you need, but I'd order it from st charles isuzu if I were you. They'd be able to tell you which one you needed and it would be a true OEM and it may be cheaper with free shipping. Check out the FAQ's for the number http://isuzufaq.ibctech.ca/#faq11 and look over them all, a lot of good stuff. I get most of my stuff from st charles.
marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 02-23-2006, 01:09 PM
Ok, thanks Marc. I appreciate it. I'll be around here quite abit for the next couple months. Gotta get all the little demons out of a trooper that hasn't been driven in about 3 months. Then come the 2.5" lift and the beefy tires.
thanks again.
Old 02-23-2006, 02:13 PM
rodeo02 rodeo02 is offline
There are only 2 kinds. One that pushes into & one that threads into the valve cover. You need to look & see which you have. I doubt the original needs to be replaced, as a cleaning usually turns them into new again, but new certainly wouldn't hurt.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
