Fiesta using too much oil. What happening?
My fiesta is using way too much oil ( nearly 1 litre a week ) but its not leaking. What could cause this? The engine is not dirty and the smoke from the tail pipe doesnt seem to be dark.
Re: Fiesta using too much oil. What happening?
Is your engine dirty? If yes then you have a leak(s) somewhere.
Worn rings and/or valve guides may allow your motor to burn the oil. Dark or blue smoke from the tail pipe is an indication of this. |
yh i have the same problem with my fiesta quartz 1.1 (95) i bought it wv oil in the middle on the dipstick and as you use the car it slowly decreases and jus as alijodie sed theres no leaking from the car.
if any1 has any useful tips or diy ideas be greatly appreciated and also ill put my solutions up thnx Andy |
hey everyone may have a solution, i was origianlly using bp ultimate which was a bad idea as i was using it way to quickly i then gt a tip from a friend to use 50w 40 oil, so got sum dirt cheap thick oil, this helped alot i used 2 litres of oil in jus over 2 wks which was a great improved.
hope this helps thnx |
take off the oil filler cap and run the engine. If there is a misty vapour coming out then your bores are worn. jus keep puttin oil in it, or get another engine. It wont blow up or anythin as long as you keep puttin oil in
