Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-23-2006, 10:20 AM
cancer3413 cancer3413 is offline
Question Headlights
I have a problem with my daytime running lights and one bright light
I have a 1998 sunfire and the one way my lights will work is if i put on my high beams-- then only the right side have the high beam and the left light is deam. if i turn off the high beams none of the lights work. Please help!
Old 02-23-2006, 10:38 AM
TheGuyz TheGuyz is offline
Re: Headlights
I just started trouble shooting my headlight issue and came across similiar sitiaution while repairing.
At the middle of front bumper is a relay and a bunch of wire going to it, have headlights on and move slighly the wire bunch, if this gets you a brighter light it means there is a loose contact in your relay or bad wire.
Now you can remove the left headlight and push on the pink wire( used for high beams ) and wiggle it as well, or if you have a voltmeter see if voltage if not your pink wire is broken going to headlight to switch in car.
Another note, if you DRL light is not on in dash or is flashing means a couple of issues may be at same time ( relay @ bumper or module in dash , and possible broken wire )
Old 02-25-2006, 09:53 PM
masterjess masterjess is offline
Re: Headlights
I am also having problem with my headlights, it always on DIM. I just got my used sunfire, 1997 with 2.2L engine. I am not sure if this is normal. Switch is ON or OFF position it has no effect, headlights always dim, cluster lights and parking lights comes on with the swicth in the ON position. High beam doesn't stay, when I released my finger the high beam goes back to low beam and its dim. Any help would gladly appreciated.
Jesse
Old 02-28-2006, 12:33 PM
GMacK105 GMacK105 is offline
Re: Headlights
I have seen this problem alot on these cars. It has always been a broken wire at the shrink wrap connection on the headlight wiring harness. this is located ontop of the bumper rebar. You just have to remove the radiator cover and headlights, then peel off the tape and wire loom.
Old 03-01-2006, 05:57 PM
Re: Headlights
thanx for all the tips, I will try tracing where the bad wire, if can't find it, I just leave as is.
Old 04-12-2006, 07:03 PM
ThePrairieProphet ThePrairieProphet is offline
Send a message via MSN to ThePrairieProphet Send a message via Yahoo to ThePrairieProphet
Re: Headlights
masterjess, wondering if you found your problem. i've had this problem reoccur a number of times, and every time i've had to replace my headlight/signal light control arm. there's wiring in there that goes bad, does yours have cruise control?
What the hell does rant mean?
www.stillseed.com
Old 04-12-2006, 11:40 PM
Re: Headlights
I just hardwired my headlights direct to switch( pink wire ). I having working high and low but no DRL or indicator on which is on ( high beam indicator always on )
There are many spots these cables can be broken, at radiator or under the washer bottle.
Old 04-13-2006, 10:58 PM
Re: Headlights
I was trying to trouble shoot where the bad wire (if there really a bad wire) last Sunday. I was at the middle of trouble shooting then its started to rain. So I'll had to stop. I wasn't even sure where to start. Anyway. Do I need to ohm the connection of pink wire from the drl relay to the headlight? And yes, I have cruise control on my car.
Old 05-10-2006, 08:11 PM
IH8Deuces IH8Deuces is offline
Re: Headlights
I tried a couple wites, grounds, etc, finally I bought a $17 upgraded wiring harness on eBay and connected it to the good socket. Two wires to the batter, two wires to the ground, and wham... it works fine and passes NJ inspection.
Old 05-08-2007, 09:20 PM
MetalX MetalX is offline
Re: Headlights
i just started to get this problem on my 1998 Pontiac sunfire GT. When i turn the low beams on they are really dim and the high beam light comes on even when it is set to just low beams. My high beams still work though, just not my low beams they stay really dim
Old 05-09-2007, 09:11 PM
Re: Headlights
I found out that it was my Tree Switch is broken. The swicth coz about $55.00 at the Auto Zone. If you are planning to install it yourself, be very careful becoz of the airbag might deploy.
Old 01-01-2008, 03:00 PM
katts katts is offline
Re: Headlights
HAving similar problem here Drivers headlight out on lowbeam works on high initially thought blown bulb, replaced no luck still no low beam. Proceed to check voltage on wiring to light socket get 12v on pin wire and on center blue wire but nothing on other blue.
MY understandinig is the pink is for high beam operation so why would it have constant 12v when low on not high???
IS my switch toasted?
is it bad wiring?
any help or suggestions would be greatly appreciated
katts
Old 01-02-2008, 05:11 PM
Re: Headlights
i had a bad tray switch it cost around $55 in discount auto parts. i haven't replace it yet cos im afraid airbag migth deploy. my niegboor told me that i can unhook the battery to disable the entire system. anyway i ran a new set of wire with one position switch it took me about 15 minutes to do it and an hour to figure how the wiring scheme.
is it bad wiring?
katts
Old 01-13-2008, 07:37 PM
vulcan_03 vulcan_03 is offline
Re: Headlights
I have the same thing with my 2000 sunfire GT.....have replaced the switch on the steering three times now......found out thats not the problem at all......sure works for a little while after replacement but thats not the initial problem...its behind the faring on the front..have to remove faring and battery and the wire leading to left front headlight will be burnt out.......guaranteed........know someone else with same car...same problem same solution.....go firgure.........
Old 01-19-2008, 03:21 PM
mattoreo21 mattoreo21 is offline
Exclamation Re: Headlights
Had same problem on my sunfire, check all the fuses please I spent $350.00 at repair shops trying to fix it and all it was was a fuse! My sister found the problem $1.25 to fix $350.00 to learn.
