Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-23-2006, 03:07 AM
AndrewMack AndrewMack is offline
HELP 87 cutlass ciera
I bought this car and the guy told me it only needed two things, valve cover gasket and break pads, well after having to replace the rotors and getting the rear drum breaks fixed aswell i was told there was a major oil leak. the mechanic told me there are 3 places it can be leaking from, either the front main oil seal, crankshaft seal or camshaft seal. how hard would it be to replace one of these and what should a normal shop charge me. I allready got ripped off once and cant afford it to happen again. Thanks
Andrew
Old 02-23-2006, 05:20 PM
niccaleb112602 niccaleb112602 is offline
Re: HELP 87 cutlass ciera
always get a second opinion....
Old 02-23-2006, 06:09 PM
maxwedge maxwedge is offline
A990 racer
How perfect was a 19 year old car going to be, these things are to be expected.
Old 02-24-2006, 12:15 AM
Now there is a knocking noise coming from the engine. sitting in the passanger seat its coming from the right hand side? sounds like a lifter an timing chain, or maybe its a rod knocking. perhaps i should try premium fuel to help with the knocking? Anyone know how to get the door panels off without the door open, my passenger front door wont open, and my seatbelt will not release anyway of fixing that?
Thanks, Andrew
Old 02-25-2006, 04:16 PM
can anyone help with the above stated?
Old 02-25-2006, 06:38 PM
A990 racer
Exclamation Re: HELP 87 cutlass ciera
Forget the door panel find out about the engine knock, first priority, no premium is not the answer.
Old 02-25-2006, 11:50 PM
Well if the motor stays running for 3-4 months i will be happy cause by then ill have a good down payment saved up for a new vehicle. i did the motor oil stop leak thing and it seems to have worked great. how long after doing the stop leak can i do an oil change? i was going to change to 20w-50, the guy at advance auto said the heavier thicker oil would quite the "knock" down a good bit. he also said it sounds like the lifter and timing chain, but also might be something else. i know there is no cheap way to fix it so i just want to try an make do with it untill i can buy a new car. any tips would be perfect.... please and thanks for all the help
Old 02-26-2006, 09:20 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Can you tell us what size engine this has? That would help with diagnosing your problem.
Old 02-26-2006, 05:19 PM
I believe it is the 3.3L v6 and it seems like the noise is getting a little worse, and when i put it in to gear the motor jumps real hard
Old 02-26-2006, 06:55 PM
Mrbizness1 Mrbizness1 is offline
The car is not worth much. I wouldn't put another dime in it. Run it till it drops and by another $200.00 car.
Old 02-27-2006, 10:43 PM
it might not be worth much but after paying 550 + breaks etc... came out to 800. that was all the extra cash i had, im gunna save a little and try to get this fixed so it will last me 6-12months, any idea at what it might be and the cost of repair?
Old 07-21-2006, 01:49 PM
tword99 tword99 is offline
Send a message via Yahoo to tword99
if it go to the shop, you may as well drop the pants grab your ankles 400-700
