Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-23-2006, 02:55 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Just installed Greddy Profec-B SpecII EBC, absolutely amazing.
Though I've had the darn thing sitting since I did a local pick-up on it (and the wireless remote switch) for only $220 brand new several months ago, I only recently got around to having it installed.
I can't emphasize how amazing this thing is. My boost is rock solid at 12 psi, and both creep and spike are fully under control with the limiter and gain functions. I can't believe the difference.
Before, when I was running no boost control at all with my current set-up, I would constantly somehow boost creep over the injector limit and I'm pretty sure I'd get what felt like fuel cut (though some people thought it wasn't f-cut) over 4K RPMs in higher gears.
When I had the stock set-up with a manual boost controller (JoeP), spike was pretty bad too. But this Greddy Profec EBC just knocked the socks of everything else. With guage playback, you can see it almost creep over the set 12 psi, but then watch the limiter literaly drag the boost down to 12 and just hold it there. Plus that remote switching system is really cool, you just press the button and it'll revert to high boost settings you already input, and vice-versa for daily driving boost. I love this thing!!!
The daily driver. The weekend cruiser. The lazy shop hog.
Old 02-23-2006, 03:59 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: Just installed Greddy Profec-B SpecII EBC, absolutely amazing.
why are you only runing 12 lbs of boost with your set up????
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-23-2006, 03:56 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
good to know. I wanted to get an EBC for my b-day, I'm sick of having to get out of my car and do some test runs to switch from 15-20psi. That's an amazing price though, let me know if you see it in that range again.
now - 2000 civic
soon - 2002 is300
Old 02-23-2006, 04:03 PM
Shpyder's Avatar
Moderate moderator
That's the LO boost setting for daily driving. HI is set to 15 psi. With no A/F upgrades, it won't be seeing more boost than that. The block won't take more than 25 psi.
Old 02-23-2006, 05:33 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Sounds cool. Hopefully soon I will be able to talk this turbo talk (hint, hint)
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 02-23-2006, 06:56 PM
you spent all that money and have no fuel upgrades????
now - 2000 civic
soon - 2002 is300
Old 02-23-2006, 07:16 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I've wanted to get a profec b for a while but they are so much money, definatly a good buy sphyder
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-23-2006, 07:19 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
You mean you won't put it at more than 25 psi or it can't take it!?!?! Thats pretty bad i it can only take 25 psi. Why did you have the ebc installed? They're not hard to put in. I have the profec e-01 and it's sweet too i''m sure they're pretty similar.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-23-2006, 07:43 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Yes it will. Matter of fact, they tested the Evo III 16g (like yours) on their 10:1 high compression engine and made 436 ft/lbs 397 WHP @ 30psi
DSM geek
Old 02-23-2006, 08:11 PM
kjewer1 kjewer1 is offline
AF - Advisor
I ran an old skool Profec B in the 2g for over 4 years, and this is why. EBCs are badass. Not a necessity, but a luxury that I thoroughly enjoyed It was only good to 26 psi though, and I had to get fancy with some generic air pressure regulators and dual port external wastegates to get up to 30 psi. In the EVO I'm running the Profec B type S or whatever they call it. Much less complicated than the spec 2, just 3 knobs like the old skool version, but good to 43.5 psi. I upgarded the actuator in the EVO to a 17 psi spring, so I'm good to 34 psi now. Works like a champ.
By definition boost creep can't be caused by a boost controller, or fixed by one, but there may have been other factors that affected things. Spike is all about the boost controller though, and it's something I've never had to deal with using an EBC.
I'm also a little confused about the 25 psi comment. Stock blocks are running 10s at over 30 psi, and a much more worthwhile 30 psi at that (600 whp 30 psi vs 4-500 whp 30 psi). PSI is a bad unit to reference a blocks mechanical limits anyway, but I won't go into that again... Turn up the boost till that fucker breaks, IMO. That's what we pay the big bucks for built motors for after all...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-23-2006, 08:12 PM
Shpyder's Avatar
Moderate moderator
I'm pretty confused too, since stock blocks can run what Kevin just mentioned. SBR told me to keep the boost down to 25 for some reason...
As for the creep going away, I'm not to sure how that happened. It only stopped after I installed the EBC; before that, it would ceep hard all the way up to 22 psi without any boost control, and I'd get what felt like fuel cut.
Old 02-23-2006, 11:28 PM
ez1286's Avatar
Maybe they just say that so they don't have to replace engines that people boost too high (if they offer a warranty that is)
EDIT: So they said 25psi and it's set at 15? Come on!!!
Old 02-24-2006, 12:39 AM
MexRocket's Avatar
MexRocket MexRocket is offline
Now now, I'm sure it's more for his piece of mind that he knows that under 25PSI he won't have to deal with buying more stuff for the car, I think it's more psychological than limitations on the block.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 02-24-2006, 03:10 AM
Shpyder's Avatar
Moderate moderator
It's my daily driver until all the belts and pumps are changed on the 3000gt, so 12-15 is fine.
The limitations on the block were presented to me by SBR. I had a talk with Craig, the motor guy at SBR who worked on the block. I asked him why this block couldnt take more than 25 psi if a stocker 6-bolt could (when I first purchased the block), and then some. I didn't really get a straight answer to my question, though I'll email him again (especially with the upgraded pistons and rods you'd think that this engine would handle more boost than a stocker). Besides, with no A/F stuff going on at the moment, I'd rather play it safe until it's actually "retired" to weekend car status and DSMLink's in the mail
Old 02-24-2006, 11:16 AM
I'd be willing to bet SBR wasn't about to take liability in telling you your block could handle more then 25psi because of that 1 in 100 retard that granades his engine becasue he has a B&M fpr, stock injectors and 20g! As soon as you get the Link back from Dave, you'll know whats safe, and whats not when start logging knock..
DSM geek
