Old 02-23-2006, 01:00 AM
arrowhead_limo arrowhead_limo is offline
question....P1810 trouble code
What do i do after i have discovered that the code is registering on my OBD II
Old 02-23-2006, 03:16 AM
Hoags's Avatar
Hoags Hoags is offline
Re: question....P1810 trouble code
Check to see if the code is listed in the new thread at the top of the threads page, Moderator Ridenour was kind enough to put a listing of the codes. If it is there it will be your starting point, it may list a part or system that will be causing a problem.
Check it out and let us know if you need help after that.
Old 02-23-2006, 03:23 AM
Hoags's Avatar
I just checked the codes and it is not listed, we are hoping that someone will help by adding the newer codes. Those listed go up to 1998.
Any way, if you do not get the answer here from another member you can check with an AutoZone parts store, I knoe they have the codes listed, Or you could even try a web search, or call a GM Dealer, they may give you the description for that trouble code.
Sorry I could not be more helpful.
Old 02-23-2006, 11:08 AM
Thanks so very much for your input..... my car is up on ramps......so i dropped the trans pan....i couldnt find where the transmission fluid pressure switch is..... or if thats what has caused my car to stop running...it had no problems with the tranny before this happened...i may try resetting the PCM....but thanks for you help....Tom
Old 02-23-2006, 04:39 PM
xonelith's Avatar
xonelith xonelith is offline
Send a message via MSN to xonelith
1810 is 'TFP Valve Position Switch Circuit'.
I guess you already found that one out though...LOL
Good Luck!
All Motor 2001 GA GT1
Milzy Motorsports
HPTuners
GrandsOntario
