Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 02-22-2006, 11:32 PM
vitali9999 vitali9999 is offline
Weard Heat problem
OK well heres the deal i got over heating problem in my nissan 240sx.
I have replaced thermostat water pump and radiator also filed up the colant the proper way bleeding all the air out. I cant find any water leaks so by the looks of it the pressure in the radiator is good. When i drive and shift at aroudn 2500-3000 rpm the car is staing in heat range, but if i push it a litle more 4500-5000 rpm shifts it will start to over heat .
I have tryed every treak i know yet nothing seems to fix the problem any ideas what else can cause this.
