are all 2wd transmissions the same
just blew transmission and was wondering if the 2wd 3kgt and stealth had the same transmission. i have '98 3kgt fwd...that's what happens if you launched at 4000k rpm's too many times
Re: are all 2wd transmissions the same
Yes the 93-99 FWD 5 speed trans is the same in the steath and 3000gt.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
Thank You
4000rpms? I can get decent launches out of the 5000-5500 area.
Black 1997 3000GT ![]() Quote:
ya, i've got to where i can smoke my tires if i launch from around 4,000 and just keep 'em spinning all the way up to 6,000. but the 'one-too-many-times' thing has got to be a killer.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Hah, well my launches may be due to the fact that I just got brand new Goodyear Eagle F1 tires
