Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-22-2006, 11:13 PM
miste2k1 miste2k1 is offline
Timing Problem
I have a 1990 Eagle Talon with an engine in it out of a 1991 Mitsubishi Galant. It is a 2.0 Liter DOHC non turbo. The timing has jumped on this car three times. The belt was replaced the first time and the car jumped again and the mechanic put it back in time thinking he didnt get it just right somehow and it jumped again. This time he replaced the Hydraulic part of the tensioner ( with a mitsubishi dealership part ). The car was drove for appx. 100 miles and the timing jumped again. The belt on the car is a dayco belt from advance auto parts. I was told that since it was not a dealership belt that was the reason for it jumping time? Is this correct? Is the dealership belt better and will fix my problem or will I be in the same problem but with more money spent? Help please!!!
Old 02-22-2006, 11:43 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Timing Problem
I don't think an aftermarket belt would create a problem like that. it is a possibility if it has less tensile strength and is stretching under load. I'm thinking its more likely that your mechanic doesn't know how to put a timing belt on (a mitsubishi) because it is very specific and most mechanics can't do it right.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
