Old 02-22-2006, 10:51 PM
mike561 mike561 is offline
another coolant question
im going to have my mechanic pressure test the coolant i geuss how you do it, because the coolant resivior tank is always draining empty after i fill it, i geussing there might be a leak somewhere then? ill have the coolant flushed completely and then will the pressure test show if theres any leakage or problems? my gp has 110k miles by the way
2006 Chevy Cobalt LS
Old 02-23-2006, 06:33 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: another coolant question
Have you done an oil analysis?
Old 02-23-2006, 10:13 AM
nope, shoud i have that done too?
Old 02-23-2006, 11:39 AM
StevePT StevePT is offline
Is your motor a 3.1L?
If so you have the classic lower intake manifold gasket failure. The gaskets can be had for around $50 for the set and the job takes a good day's worth of work.
The problem is the coolant crossover passage on the LH side of the engine is leaking coolant into the valley.
Old 02-23-2006, 12:51 PM
wlkjr's Avatar
A $20 oil analysis should tell you if you are getting antifreeze into your oil. I just did an oil analysis on my mother's 2001 Century with the 3.1 with just 40,000 miles on it and the potassium was 122 which is really high. I'm afraid she is due for the gasket job.
Old 02-23-2006, 01:32 PM
actually my engine is the 3.8 liter supercharged, but would that be the same thing though?
Old 02-23-2006, 01:41 PM
wlkjr's Avatar
I'm not as familiar with the gasket woes as some of the others are, but I think the 3.1's are worse than the 3.8's are. Still, an oil analysis will tell you a lot about your oil and also the wear of your engine.
Old 02-23-2006, 02:10 PM
alright, ill mention these things to my mechanic then, just so i have an idea of whats goin on and what kind of work im expecting to be done. thanks for your help.
