Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-22-2006, 10:25 PM
knotters2006 knotters2006 is offline
timing
ok i have a 95 eagle talon esi n/t, i trade a bike for the car and the past owner told it only needed a water pump so i tear the engine apart put a new belt and water pump on , i lined the marks up where they had it .....now the cars runs but no very good ....it sounds like its flooding out ...i have tryed everything , could the timing be a few degrees off and do i have to take everything back off to retime it?.
Old 02-22-2006, 10:43 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: timing
The iming being off would cause it to idle very rough and missfire so if thats what its doing then yes it probably is. You can check with a timing light and see for sure. As for retiming it I believe you can just take the tensioner off or losen it or whatever and move the gears around
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-22-2006, 10:55 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: timing
Make sure the crank sproket and balance shaft sproket are lined up, your crank sproket has a plate and a sensor that control your firing.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-22-2006, 11:01 PM
blk_srt's Avatar
Re: timing
Remember hes talking about a 420a, I guess I dont know a whole lot about them but I wasnt sure if you knew that or not lol
Mods:
Old 02-23-2006, 10:14 AM
Re: timing
thank you for the tips , i would like a little more info plz.
