Old 02-22-2006, 09:34 PM
urbanj51 urbanj51 is offline
sticky lifters or blown rod/bearing
recently had intake manifold replaced. engine was overheating and no heat because of pressure fluctuations in radiator
a couple weeks later lifters started clicking. my friend who had same situation with one of his cars said it was just noisy lifters. took car to dealer and they said it was a blown rod/bearing.
anyone have any ideas?
whats the easiest/cheapest way to fix?
Old 02-23-2006, 11:50 PM
Re: sticky lifters or blown rod/bearing
any help or ideas is gratefully accepted!!!!
Old 02-23-2006, 11:59 PM
Jeremy Fitch Jeremy Fitch is offline
Send a message via Yahoo to Jeremy Fitch
Any chance you can record a sound file of it? I went through the whole intake manifold blowing thing and it was my main bearings that went out.
1996 Blazer LT 4 Door, 4x4, 4.3L Vin W.
Old 02-24-2006, 06:08 AM
blazee's Avatar
blazee blazee is offline
Problem?
A lot of people seem to have problems with their main bearings after replacing the intake gasket.
Old 02-24-2006, 06:02 PM
I can try and get a sound recorded but my computer has been acting kind of funny. but thanks for the info. i just hope that my main bearings didn't go out. did you have to replace the entire engine? or did you just go in the engine and replace the bearings and rods?
Old 02-24-2006, 11:09 PM
I had the entire engine rebuilt, including new pistons, rings, ect. I also needed a new crank shaft in mine, basicly a whole new bottom end. But yours may not need all that, there is no sure way to know what all it will need without pulling the engine and seeing what condition everything is in. However is it is just lifters they can be replaced without pulling the engine.
One old trick to find bad rod bearings is to pull the plug wire at the distrubitor to each cylinder one at a time, be careful not to get shocked, and listen to see if the sound gets quieter on one cylinder, if it does then its probably a rod bearing. If the sound gets louder then its probably main bearing. If no change then it could be lifters or cam bearings.
Old 02-25-2006, 03:12 AM
534BC 534BC is offline
Well, block distortion is a very real thing, but I can't figure out how the intake bolts get so much distortion to the mains that it causes a main bearing failure. sounds kinda fishy to me. There must be more to it.
Old 02-25-2006, 04:58 AM
blazee's Avatar
Problem?
It seems a little far fetched to me, too. I think that its more likely a result of the bearings being damaged due to coolant seeping into the oil through the leaking intake gasket.
Old 02-25-2006, 09:33 PM
I think thats the problem also. It took mine 4 months after the intake went before the mains went out. If it were blobk distortion I would think it would have been sooner.
Old 02-26-2006, 03:15 AM
AJT1961 AJT1961 is offline
It's been 1000 miles since I replaced my intake gasket and lifters. I thought I was home free but I guess I have to keep my fingers crossed hoping that the main bearings don't go next.
Old 02-26-2006, 08:08 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Ok, lets digress a bit and go back to the basics and move up:
1.) What oil and what oil filter are you using?
2.) Have you flushed your oil system yet?
3.) Is the sound seem less pronounced when cold?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-26-2006, 12:34 PM
Yes, water in oil would be easy to see in the bottom of pan. One thing is for sure, if it's a rod bearing you wil find out real soon. lol
Old 02-28-2006, 09:02 PM
sry i haven't replied in a few days but i've been real busy. after i looked at the engine and oil pan i realized that i have an oil leak. i think its cause the oil filter is a fram, which i bought the car with and i assume the same type of filter that has been replaced every time i get my oil changed. i think that the bearings haven't been getting a sufficient oil supply which is making them go out.
Old 02-28-2006, 09:18 PM
BlazerLT's Avatar
AF -Advisor
What oil are you using?
How much oil are they putting in your truck when they are filling it during a change.
Have you done a oil flush and if not, I would do it.
Old 03-01-2006, 10:16 PM
i'm using whatever they're putting in there when i get it changed. i think its 5w-30. they've been putting 4 quarts like suggested by gm
