Old 02-22-2006, 09:29 PM
The Reverend Stu The Reverend Stu is offline
Adding A/C...
Anybody know if it's difficult (or what's involved) to add air conditioning to a CRX that didn't come with it from the factory?
Old 02-22-2006, 10:59 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Adding A/C...
Wiring harness, all of the lines, the compressor, condensor, drier, evaporator, probably the whole box under the dash, the a/c switch (not sure if youll need a whole new head unit) and all sensors and relays to make it run, I believe, also may need a new ecu (correct me if I'm wrong) because you a/c runs through it...youve got your work cut out for you, Id just get one with a/c to begin with...My swapped crx had a/c and all i need is the wiring a compressor sondensor lines etc....and im going to have a helluva time with it..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-22-2006, 11:16 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: Adding A/C...
you and me, I wanted to add AC but then realized the hassle...the mechanic wanted a grand and some to do it...
Old 02-23-2006, 12:22 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: Adding A/C...
i live in the desert(tucson/az) and i would much rather have the few ponys than a/c. dont get me wroge i love it. but my need for speed is way to overpowering. and probly cuz i only got a zc and need what i can get to keep up with them b series motors. good luck tho i just removed all the ac stuff that is needed under the dash. send me a pm if you might be interested. layta
Old 02-23-2006, 01:39 PM
FrodoGT's Avatar
Re: Adding A/C...
Its only like 1-2 whp dude, 3 if youve got P/S, Ive seen the dyno charts.
Current project:
Rio Red 91 hatch.
Old 02-24-2006, 12:00 PM
Re: Adding A/C...
Thanks FrodoGT. Yeah I figured it would be alot of work. I guess I'll just have to keep looking until I find one that had A/C from the factory originally.
