Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 02-22-2006, 08:40 PM
Jajo92 Jajo92 is offline
89' Dodge daytona wiring probs
Hey, I got a 89 dodge daytona that is doing some funny stuff. I open up the passenger side door and my radio goes out, I turn on my dome light and the radio goes out, now my dome light stays on constantly so i took it out, but the radio still does not work. And today when i fixed the brakes on it, my brake lights and blinkers dont work anymore! What the hell is wrong with this thing..Mind of its own perhaps?
Old 02-23-2006, 04:53 PM
hunter_eaton hunter_eaton is offline
Re: 89' Dodge daytona wiring probs
the best bet I can say for u man is to go to the computer on u're car and take a good wiff and make sure its not burned up cuz I had some of the same type of problems when mine went and if thats not it then make sure to check its connections. Hunter
Old 02-27-2006, 12:13 PM
i replaced all the wires, fuses, fuse box...it took care of the problem...:P so thats cool.
Old 06-01-2006, 01:11 PM
TurboPacifica TurboPacifica is offline
Check all your ground cables.
a) from firewall to block
b) from the battery to body
c) I hear there should be one on the left motor mount to block
d) check the ground on your radio.
Sounds like your car is creating its own grounds.
"Power will follow the path of least resistence".
remove clean and replace what's needed.
Good Luck and happy hunting.
[email protected]
Dodge Daytona Pacifica
T-Top automatic Turbo I
