Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-22-2006, 07:39 PM
jsgold jsgold is offline
89 - 2.5 head questions
My dad's 89 Olds wagon is spewing anti freeze and along with anti freeze in oil also pressurizes the radiator so he has at the very least a bad gasket, maybe worse. It is a 2.5 and while we have a GM service manual I would appreciate any tips on removing this head. Never fooled with a 2.5 as far as doing this. Plan on taking it to a shop for testing, unless we see obvious problems. How difficult a procedure is this?
I used to be indecisive, now I am not so sure.
Old 03-06-2006, 11:04 AM
Re: 89 - 2.5 head questions
To add, it has been suggested I replace the head bolts, even though Gm manual does not specify. We are going to pull the head this coming weekend, just wondering if anyone has done this on this particular motor? 89 olds cutlass ceira wagon, 2.5L. Have a question on the torque on the head bolts as well, manual is not clear on that. says to tighten in a criss cross pattern (same as any head) but, after torqued to 25ft lbs, says to turn 3/4 turn. usually i see head bolts torqued up to a maximum point, not a 3/4 turn etc.
Old 03-06-2006, 01:16 PM
GTP Dad GTP Dad is offline
Pontiac Guy
I have not done work on this engine but the book states to remove the head just like any other, nothing special but I recommend that you label everything so that it goes back together easily. As for the head bolts the torque sequence is 10 6 2 3 9
8 5 1 4 7
All head bolts are to be torqued to 18 foot pounds on the first pass, then in the second step of torque go to 26 foot pounds on all bolts except #9 this one stays at 18 foot pounds. Mark all bolts with a marker and then turn each bolt 1/4 turn additional. You must apply sealer to bolts #9 and #10.
Old 03-06-2006, 01:24 PM
Thanks very much. We have a service manual but it did not mention the sealer and I was confused on the torque specs. Really appreciate it. Just curious, would you advise replacing the bolts?? I did not see that either in book, but, was told that it was recommended. The old car is not worth putting a lot of money into, but, I want to do the job properly.
Old 03-06-2006, 06:08 PM
Pontiac Guy
The book I have does not say that they are torque to yield but my philosophy has always been to air on the side of caution so that I didn't have to redo the job. So if you are in doubt replace them if for nothing more than piece of mind.
Old 03-06-2006, 08:36 PM
Sounds like good advice. I see they are not a lot of money so unless we find major trouble with it I'll buy a set of bolts. Thanks again!
Old 03-08-2006, 12:03 AM
mcrosby mcrosby is offline
jsgold,
Did you already do the head job? I had a '88 Olds Calais that had the 2.5 and have done a head replacement 2 times. Just wondering.
Old 03-08-2006, 11:12 AM
No, we are supposed to pull the head Saturday morning up at my dad's place. Unsure how tough this will be. I am concerned that the old one may be cracked with the way it was acting. A lot of pressure in cooling system, a LOT of coolant in oil, really blowing out steam when he got it back home. How difficult would you rate this, as far as removal goes?
Old 03-09-2006, 04:10 AM
Actually, I found the heads on my 2.5 Calais to be one of the easiest heads to replace that I have ever done. I think you have more experience than me, so you should find it a snap. You will want to replace the head bolts and I think you already know, there is one bolt that has a different torque than the rest. The Haynes manual does recommend replacing the bolts and I believe they are torqued to yield. Haynes is really good on this engine. You will find it an enjoyable repair I am sure. By the way, this engine is notorious for bad coil packs, so you may want to just replace them while you are at it.
Good luck,
Mike
Old 03-11-2006, 04:23 PM
Well, the head came off failry easily. Just a lot of hoses and wires to deal with and it is heavier than I thought it would be. Of course being made of cast iron does not help. Gasket was in bad shape. Do not see any cracks in the head but brought it back to my house along with the intake and exhaust manifolds (still attached) for better look. Am going to drop it off at a machine shop for a second opinon and possible additional work(seals etc). If all is OK I guess we will put it back together later next weekend. As for the coil pack, yes they are bad about failing. In fact we had to replace the igniton assy last summer which was a real pain. No room to work, had to use mirrors, block up motor, unhook engine mount, you name it. Without the head and manifold it is right there, easy to get to. Oh well, hopefully we won't have to do either of these things again on this old car. Will post when it is fixed. Thanks for all of the input!
Old 03-18-2006, 04:58 PM
Well just an update, the head is indeed cracked. I saw nothing myself but after taking to a good machine shop where it was disasembled, cleaned and checked there was a hairline crack under the exhaust valve, non repairable. Only cost me 25 bucks to do this(would have been 112 to re assemble, install new seals,have it decked etc. had it been good) so I am glad I did this although I wish it had been a different outcome. Now looking for another head. These folks have one for 250 bucks, may be a week or two before we have enough cash to get it but that seems a fair price. Just an example of how a person should get these things checked. Would not have seen it on my own.
Old 03-19-2006, 09:52 AM
Pontiac Guy
Check car-part.com for a good used one. They are getting hard to find but there should be a few out there. This should save you some money.
Old 03-21-2006, 12:16 PM
Thanks for the information. Will save this site on my favorites as it looks very helpful. Am trying to get one off Ebay right now, unit is rebuilt, seller 100% rating, might be able to get < $150. If not then I will look at this site some more.
http://cgi.ebay.com/ebaymotors/ws/eB...ABCA%3AUS%3A11
Old 04-15-2006, 01:11 PM
Just one question on the head bolts. We will finally start putting this old car back together next weekend and I noticed that only one of the new studed headbolts (I assume number 9) has thread sealing compound on it new and number ten does not. I have d/c and this is the way new hedbolts come for this engine. I still do not see anything that mentions this in GM manual, other than torquing and sequence, so I am wondering if I should just install as is or get some kind of compound for the other one? If so, what type do i get?
Old 04-15-2006, 04:06 PM
Pontiac Guy
Just install as is. They often come new with the sealer on the ones that need it. If you put sealer on other bolts you may not get proper torque. also if I remember correctly the No. 9 bolt has a different torque number than the rest anyway. Probably the only one that enters a water jacket.
