Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-22-2006, 06:10 PM
95GSTRaCeR 95GSTRaCeR is offline
Exclamation fuel issue
Hey everyone. I just bought a 97 Eclipse GSX with a 6 bolt swap. Last thursday the turbo went out, so I spent friday putting a new one in it, I drove it around that night and it drove good except it would almost stall whenever I stopped. It has done this before, not as bad though. On saturday morning I started it and after about 1-2 min of running it died, and now all it does is crank. I pulled the backseat and access panel to the fuel pump out, and when the key is in the on position you cant hear the pump. So I pulled the pump out and hooked it to direct power and it works. I also pulled the computer out and the capacitors are fine. The only thing I havent checked is the Fuel Pump Relay and that is because I dont know where it is at. Any help would be appreciated. Thanks.
Old 02-22-2006, 06:12 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: fuel issue
FP Relay should be under the hood, but I would take a volt meter and test the wires in the connecters under ur back seat to make sure your getting power. That is, in addition to checking the relay, that way if the relay is good, you fried a wire or something became disconnected.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-22-2006, 06:16 PM
Re: fuel issue
I checked for power at the fuel pump and there wasnt any. Where exactly would the relay be under the hood? I was also told that it would be behind the stereo but not exactly where..
Old 02-22-2006, 06:29 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: fuel issue
It's just one of the relays in the fuse box under the hood. It should say on the cover(underneath). If it's not that....then this might be a chance to do a fuel pump rewire mod
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 02-22-2006, 08:33 PM
Re: fuel issue
Exactly, most likely is the relay went bad, sorry though, im not sure of the exact position, but I know it is under the hood with all the other relays
95 Eclipse GS-T
Currently:
Soon lol
Old 02-22-2006, 08:54 PM
Re: fuel issue
Im not with the car right now, so I could be wrong, but I checked earlier and I dont remember there being a relay there, i'll check later. Thanks for all the help.
Old 02-22-2006, 09:41 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: fuel issue
The fuel pump wont run until you start cranking. Its an ingenious idea thought up by Chrysler
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
