Code Question
I have a 97 gtp and its check engine light is on. I went to Autozone and they said the code that was causing the light to come on was PO441 Emissions Purge Flow System Fault. I am clueless to what the problem could be but i need to get this fixed ASAP because i just got a ticket for inspired inspection a few days ago. Thanks for any suggestions
Re: Code Question
Purge flow valve could be stuck open or closed, sits on the vapor cannister, further diagnosis is required to find this problem accurately.
Re: Code Question
ok, can you tell me further where that is? or could my chiltons tell me that?
Re: Code Question
Check all of your vacuum lines in the evaporative emissions system. At rear of car by the fuel tank on driver's side there is a charcoal cannister with the vent solenoid. Check there and where they go to the fuel tank. Then where the lines run back to the engine.
On the engine side check vacuum connections from the throttle body to the purge solenoid. Also, check electrical connections at the vent solenoid and purge solenoid for corrosion and tightness.
Re: Code Question
i went today to get my car inspected because i turned my check engine light off and i was seeing if i could sneak by, but it still failed.. they said my car was fine except it was running too lean.. they said to check my o2 sensor and maybe that was it.. what do yall think about that?
Re: Code Question
You failed with no cel on and no pending codes? what state is this. Also when you clear the codes it takes a specific drive cycle to reset the emissions monitors, in NYS you would fail if you had just cleared the codes and came in for an obd11 emissions test.
Re: Code Question
i live in texas and i did have a pending code still, but i reset my computer so it didnt show up. after a while of them driving it around and messing with it, when they plugged it up, they said it finally threw the code again and it was running to lean..
a few months ago my CAT was clogged so i undid my 02 sensor under the hood to let out some pressure. my cylinder 6 wire was back there and the exhaust basically melted the 6wire. do you think that it could have damaged the o2 sensor too and i just need to replace it to make it not run too lean? |
Re: Code Question
Re: Code Question
i went to autozone and the code reader said PO441 Purge Flow system fault
i went to get it inspected and they said it was running too lean yes i got the cat replaced a few months back so you say that maybe i should replace the o2 sensor (before the cat under the hood)??? |
P0441 is not related to running lean, how did they determine that, no code was present for it, so it should not be an issue in the inspection.
Re: Code Question
i wish i could tell you.. i was thinking the same thing though, that the evap system has nothing to do with running lean..
this is so frustrating.. i dont know what to do..... i guess im just going to have to pay full price for this ticket and pay to get another inspection done some other time because i dont see this problem getting fixed in the next 3 days unless one of yall are a genius and can figure this out.. |
Re: Code Question
Re: Code Question
Ok, well i was rereading the inspection papers and it says that it actually threw a different code this time.. it is P0171 System too Lean (Bank 1)
so maybe it is my O2 sensor? i dont know what all this means but it also says on the monitors: Misfire: Ready Fuel Sys: Ready Comp Cmpt: ready Catalyst: Not Ready Heated Cat N/S Evap: N/S 2ndSys: N/S Air Cond: N/S O2 sens: Not Ready 02 Sens Htr: Not Ready EGR Sys: Not Ready DLC: PASS Fault Codes P0171 System too lean (Bank 1) maybe all the not readys have something to do with me reseting my computer right before i took it to get inspected. What does the N/S, Ready, and Not ready mean? im about to go back up to autozone to see what codes are being thrown again. |
Re: Code Question
Here is the course of action per the GP GM service manual: Check all vacuum hoses at intake system. PCV Valve Possible throttle body blockage (clean input screen and body) IAC (idle air controller valve) Check fuel injectors (bad o-ring seal) MAF sensor EGR valve Check 02 sensor
Re: Code Question
The other monitors are not ready because after clearing the codes there is a drive cycle required to set the emissions monitors, which can also cause an emissions test failure because it cannot check certain required components.
