Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 02-22-2006, 04:01 PM
Bro-Bro Bro-Bro is offline
Help Me!!!!
I've got an 84 b150 van. the starter is trying, thought it was the coil, bought a new coil , not the problem. It ran great then the battery died and now it won't start. New battery, new coil, no good. Any Ideas?
Old 02-22-2006, 04:02 PM
Re: Help Me!!!!
[quote=Bro-Bro] I've got an 84 b150 van. the starter is trying, thought it was the coil, bought a new coil , not the problem. It ran great then the battery died and now it won't start. New battery, new coil, no good. Any Ideas?
Old 02-25-2006, 02:49 PM
98Pontranport's Avatar
98Pontranport 98Pontranport is offline
Send a message via AIM to 98Pontranport
Re: Help Me!!!!
Did you start it so much that you killed the battery? It could be a dead alternator if the battery is not keeping a charge.
1986 Dodge Ram Van B150, 318 V8
Sweet!
Old 02-25-2006, 04:38 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: Help Me!!!!
Will it start if you use a shot of starting fluid in the carb? could be it's been flooded to the point where the spark plugs are shorting out, if thats the case the only reliable fix is the replace them.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-03-2006, 03:22 PM
bignoisey bignoisey is offline
Re: Help Me!!!!
You've probably found the trouble by now , but here's what I told the other guy with the '86:
Check the battery cables and starter wiring for loose or corroded connections. These cables have to support a lot of current to run the starter. If the starter is bad you can sometimes repair it with a new set of brushes or just replace the solenoid. I've even opened up solenoids and cleaned the high current contacts to make them work again. Once I even was able to just tighten the screws holding the field magnet in place to fix a starter. But all this may be getting into too much time spent and you'll just want to get a new or rebuilt starter by that time
