Old 02-22-2006, 02:59 PM
thehugger thehugger is offline
1989 Camaro ignition issue
I have an '89 Camaro that I just recently purchased. every so often when I go to turn the ignition, nothing will happen. I have interior lights and radio but no ignition. I want to believe that the issue lies within the coded key but am not sure. I have tried checking the shift selector wiring and everything seems to be in order. Has anyone had this problem? If, so is there a fix besides replacing the ignition switch?
Old 02-22-2006, 04:19 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 1989 Camaro ignition issue
Sounds like the switch IS your problem, especially if you use your tilt steering alot.
It would still crank with a VATS problem
Old 02-22-2006, 06:18 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Im not shure about that wright, I have an 89 camaro aswell and when my vats used to act up, it wouldnt let the engine crank at all...tried to start the car and all I heard was a "click/tick" sound and then nothing...
I got the bypass module from ecklerscamaro and I havent had that problem since, so I know it was the vats and not the switch.
I know you know your stuff, but I have to disagree with you on this one.
Old 02-22-2006, 09:22 PM
A security override module from ecklerscamaro.com will solve your problem, it did for me
Old 02-22-2006, 10:02 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
again like i have said in other post, check your fuses first!!
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-22-2006, 10:46 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
VATS will NOT let it still crank.
Old 02-23-2006, 09:00 AM
wrightz28's Avatar
Dunno what the hell I was thinking there. For some reason i thought It just killed off spark and fuel grounding. My bad.
Old 02-23-2006, 09:36 AM
Thanks for all of the help. I am going to try the security bypass from ecklers and see if that works. I don't think its VATS because its intermitant. And when I let it sit for a few minutes then the engine cranks.
Old 02-23-2006, 10:53 AM
wrightz28's Avatar
When the problem occurs, the only thing I can suggest is try to see if you have battery voltage on the S terminal of the starter solenoid. I know it's a tight to get in there, but atleast that will help nail down if it's a ignition switch (still sticking to my guns on that one) or a faulty winding in the solenoid.
Old 02-23-2006, 07:19 PM
Brilliant! I will try that this weekend when I can get under the car. Thanks!
Old 02-24-2006, 04:20 AM
Im sticking to my guns on this one to..lol
I really do think its the VATS...and after the above statement by hugger, Im certain that the problem is the VATS, I had to deal with if for several months before I found out what it was for shure...but now when I think back, I just kick myself because it was so obvious...why didnt I figure it out sooner?!?
