Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-27-2002, 10:20 AM
descalzo91max descalzo91max is offline
Question Transmission shifting LATE when it's COLD...
I have a 91 Maxima SE. When the engine and tranny have been sitting, in other words cold, the tranny shifts very badly. It shifts really late, and won't shift into 3rd unless I slow the engine RMPs down and then accelerate again. As the engine and transmission warm-up and get hotter, the problem decreases and almost goes completely away. I normally drive with OverDrive on, but when the RMPs get too high, because the tranny is cold and shifting late, if I turn off the OverDrive it "catches" gear, you can physically feel the "catch" occur. Say for example, I'm in 2nd, going into 3rd, and the engine RPMs are at 5000, if I turn the OverDrive off, slow down, and then accelerate, it will catch. If I just slow down and re-accelerate without turning off OverDrive, it will take a while before it catches gear.
Anyone know what the heck could be causing this!?
I need all your help...
THANKS
MAX
Old 06-27-2002, 02:47 PM
Skoodaddy Skoodaddy is offline
Trans
My '96 slips when it's hot out.
Old 06-27-2002, 04:01 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
old tranny oil could be gunkin up if ya havent changed it
Old 06-27-2002, 06:07 PM
etonic etonic is offline
Talking Nissan Has a TSB
Nissan has a TSB out for harsh, erratic, or late shifts when cold. Recommends you change your tranny fluid and replace with nissan c-matic. Check it out!
Old 07-14-2002, 12:20 AM
Davidmartin Davidmartin is offline
I had the same prblem and I fixed it
I had the same problem, actually the trasnmissions is sending a message, "I´m sick" but you can help it.
I use a TRANS X, and the problem gone
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
