Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-22-2006, 01:42 PM
gstnewb gstnewb is offline
What should I expect?
Well I timed my car 0-60 mph and it did 6.71 seconds all stock. This friday after I replace all hoses, vacuum lines, and some fluids I am also planning on installing my boost controller and the new boost gauge I got. I am thinking of boosting the pressure to 15psi from the stock 10 psi. What hp gains should I expect and what do you think my new 0-60 mph time would be? Anything bad to look for when I boost the pressure such as increased turbo lack, etc?
1990 Eclipse GS-T (STOCK)
Planned mods: 15 psi boost; turbo timer; blow-off valve; 3" catback exhaust; alum. IC pipes.. for now
Old 02-22-2006, 02:12 PM
TheRomer TheRomer is offline
Re: What should I expect?
according to my calculations... roughly 6.2854 with a wind speed of 8.923 mph. dont think we can tell you your 0-60 time exactly by your description lol, but it will def be faster. just watch the gauge and make sure u arnt running lean... lean = bad. you prob shouldnt have a problem becuz i believe the stock internals can safley go 16 psi... but then again im not sure. and with your t25 (i think u have a 2g but iforget now and dont feel like hitting back and typing again) you arnt going to notice turbo lag because its such a small crappy turbo, theres not much to lag. good luck!
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
Old 02-22-2006, 02:14 PM
ok so now i realized u have a 1g with no t25 sorry. anywayz with the 14b, its still not going to make a big difference, nothing to be worried about at all, it will still spool up fast.
Chris Winchell
I have a 1g. I know no one can give me an exact number. I was asking for stimates in case someone has done the same and used a timer to check the improvement. I think power-wise this is a simple question to answer since at least someone must have done a dyno with stock boost and then with increased boost. Maybe not. I was just wondering, that's all.
Old 02-22-2006, 04:22 PM
Old 02-22-2006, 04:34 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I know a stock 2g awd with a good tune makes around 180awhp, a fwd 1g might make ~200whp. Just a guess
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-22-2006, 04:38 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
It all honesty. You should feel a little bit more power but nothing to be amazed about, check dsmtuners.com's tech guide for ways to make your car faster or search on here, theres a million of threads on stuff like this.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 02-22-2006, 04:41 PM
blk_srt's Avatar
I actually noticed a huge gain by doing the free mods...but I guess I had some huge boost leaks so that might explain it
Mods:
Old 02-22-2006, 05:20 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
a boost controller will add a noticeable gain. Not much but it is noticeable.
And I would run 16-17 psi since you have a 14b. It can handle it just fine.
1991 GSX 2.3 Stroker
Old 02-22-2006, 06:52 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Stock can handle way more than 16psi
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 02-22-2006, 07:32 PM
blk_srt's Avatar
Stock internals yes, stock fuel system no
Mods:
Old 02-22-2006, 07:56 PM
Talon69's Avatar
Correct!!! But he only said stock internals
Current Cars
Old 02-22-2006, 07:58 PM
Yeah, the fuel system is what is limiting everything to 15 PSI for now and I don't mind that. I want to take everything slowly step by step. In the very near future I am planning on upgrading my fuel pump to the Walbro 255 from ebay and then possibly boost the turbo to its max before upgrading the turbo. Like I said, I am doing everything step by step and saving my money for now and until I make sure the car is in a reliable condition and ready for modding.
Old 02-22-2006, 09:37 PM
blk_srt's Avatar
its going to take more than a 255 if you want to run 20+ since a 14b maxes at ~22. Your looking an injectors(you can get away with the stockers since they max out at~30lbs/min which is about the same as a 14b)and your going to need a regulator with that 255.
Mods:
Old 02-22-2006, 09:54 PM
hence my.... "not postive though"
Chris Winchell
