Old 02-22-2006, 01:27 PM
tifferific77 tifferific77 is offline
Cool Humming from engine
Hi, I hope someone can help, I got a 1996 Blazer a little over a month and a half ago, I took it from St. Pete to Orlando (not that far) and when I got to Orlando there was a loud deep humming noise coming from the engine but mainly only when going slow or when stopped, it sounds like it is coming from the fan or the belt, anyone have any suggestions? Thanks a bunch1!
Old 02-22-2006, 01:33 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Humming from engine
I would try to pinpoint where the sound is coming from. It could be the belt needs replaced, idler pully, tensioner pully, alternator, power steering pump(check level), water pump, or a/c clutch.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 02-22-2006, 02:29 PM
Hey, thanks for the info, we were thinking it might be the belt, should we get belt dressing or just try to replace it? Thanks again!!
Old 02-22-2006, 02:48 PM
billibong's Avatar
billibong billibong is offline
Just replace the belt, don't waste your money on belt dressing. THe cost of the belt is fairly inexensive, ~$35.00, and it will save you trouble in the long run.
The change out of the belt is quick, maybe 15 minutes tops, and is really easy.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 02-22-2006, 03:35 PM
Thanks once again!! But can I tell if it is the actual belt that is bad? Is there some way to tell? And how easy is it to switch out, would that be in my manual by chance? Thanks again!
Old 02-22-2006, 04:20 PM
billibong's Avatar
The change out of the belt is very easy, all you need is a 3/8" breaker bar or ratchet handle. Put the breaker bar on the tensioner, it has a 3/8" opening in the center, and turn counter clockwise about 1/4 turn. Remove the old belt, replace with new belt following the diagram located on the fan shroud. You're done.
It is in the Haynes and Chiltons manuals, and is so easy you'll wonder why you didn't do it earlier.
billibong
Repairs:
Old 02-23-2006, 08:17 AM
Thumbs up Re: Humming from engine
Great! thanks again... im going to go to the store tonight and we will try to get it switched out, thanks again, you were a huge help! I really appreciate it!
Old 02-23-2006, 08:37 AM
nickledimed's Avatar
nickledimed nickledimed is offline
Send a message via Yahoo to nickledimed
While you have the belt off you can check for play on most of the pullys, if you feel something funny thats probably were the noise is coming from.
08 Equinox LT
Old 02-23-2006, 09:32 AM
Will do! thanks!! But then, im assuming that if it does feel a little weird or if the sound keeps up, I should just go ahead and bring it to a pro.? Oh and do you think this is ab-normal for a 96'? (it has a little over 85,000 miles)
Old 02-23-2006, 10:21 AM
herkyhawki herkyhawki is offline
Since you don't know the source of the noise:
Start and run the engine for a minute while the belt is removed. If you hear the noise, then you know it is internal and not related to belt or accesories. If noise is gone, but comes back after you install the belt, you know it is one of your accessories.
Old 02-23-2006, 11:54 AM
Great idea, makes complete sense, thanks once again... to all of you for all your info. and help!! youre all great!
Old 02-23-2006, 02:22 PM
billibong's Avatar
If you find that you're getting noise from the pulleys themselves, they are not that hard to replace. As long as you have access to some standard tools, and a Haynes or Chilton manual it can be done in a parking lot or garage failrly easily.
Good luck, and let us know what you find out. These posts help others that search for similar symptoms.
billibong
Repairs:
Old 02-23-2006, 03:18 PM
I dont know if we will go that far, a real mechanic might be our best bet if its not the belt... actually it is now making the noise off and on, not every time its driven... but im still going to check the belt anyway, cant hurt!
I will definitly let everyone know what happens, thanks again!
Old 02-23-2006, 10:21 PM
swalt's Avatar
swalt swalt is offline
You may want to check your PVC hoses/crankcase hoses. I had my upper intake seal done this week and when I got the truck back I was experiencing a buzzing/humming at idle and slow speed. I thought it was coming from the PVC hose in the driver side rocker. Dealer thought it was a cable vibrating against the firewall, but 2 minutes after leaving the dealership the noise was back. It ended up being the hose that runs from the passenger side rocker to the plastic cap on top of the throttle assembly. There was a rubber elbow which was not tight and leaking air. I just reversed the elbow and it went back on tighter. The buzzing was driving me nuts.
Old 02-24-2006, 05:24 AM
muddog321 muddog321 is offline
AF -Advisor
On that PCV after the intake done, the throttle cable plastic connector to the intake (on rear drivers side) bracket always ends up broken so I had to use a plastic tie to secure - the cable conducts the noise and also moves the PCV on acceleration as the engine torques up. The top of the intake can where the PCV hose goes into the intake is a removable top that you rotate to lock on 98 up, same with the power brake vac to intake.
