Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-22-2006, 08:24 AM
Truckin_S-10 Truckin_S-10 is offline
Car won't go into gear!
Hi all.. I have a 91 Integra RS which ran beauty 3 days ago. Last night I fired it up and the engine sounds great. But it seems as though the clutch is totally gone. I'm sure the break is off because the car doesn't even budge and it sounds just like it's in neutral when in gear. Also, the speedometre will act as though the car were moving when you rev it. The shifter is definately in gear. I know a clutch will slowly degrade over time, not fail all of a sudden like this.. has some bolt or pin come loose somewhere in there; on a connecting rod from the shifter to the clutch?
Any ideas?
Thanks!
Old 02-22-2006, 11:25 AM
WReX WReX is offline
Re: Car won't go into gear!
sounds like you have some major transmission problems, are you sitting still when the speedo is giving a reading?
if your sitting still, sounds to me like the diff is turning but no power is going to the wheels..? bad diff?
26 PSI anyone?
Old 02-22-2006, 06:38 PM
puckman19 puckman19 is offline
check the drive axles first, but yea. Sounds bad
Old 02-23-2006, 10:46 AM
effects effects is offline
is it possible to pop out the drive axel from the transmission causing the car to not move when put in gear?
Old 02-23-2006, 11:27 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
yes. If one of the axles is not "pooped" in all the way the car will not move when put into gear. It will act as if it is in neutral. Also the speedo will still work even though you are not moving.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 02-24-2006, 01:30 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
but the speed sensor isnt conected to the diff is it? and you have to unbolt the half shaft bearing before you can take the driver side out and i remember the pass side being a beotch to get out even with all the suspension dismantled but i have a dc2 maybe theres a difference but i cant figure the problem being in the half shaft unless you somehow unknowingly quarter shaft it. jack the front of the car up and see if there is a bigger gap in between the trans and one of the axles and then see if the wheels will spin with it off the ground (use jack stands and parking brake) and try all gears
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 02-24-2006, 09:44 AM
the speed sensor gets its reading off a speed gear on the differential
26 PSI anyone?
