Old 02-21-2006, 07:31 PM
chronicgrl_420's Avatar
chronicgrl_420 chronicgrl_420 is offline
re: HELP!! car amp
alright i checked everything. and still nothing!!! so i hook up a diffrent amp and it works fine! ODD HUH!?! well I took the pheonix gold inside and opened it up, come to find out who ever had it before me, wrote the wrong terminals on the outside for the power, remote, and ground wire. Most amps the power wire is on the left and the remote is in the middle and ground is on the right well when i opened it the remote was on the right the power in the middle and ground on the right, SO, my question is would that kill the amp if u had the power in the remote and the remote in the power???? thanxs alot!!!
Old 02-22-2006, 03:30 AM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: HELP!! car amp
By having the power wire hooked to the remote conn. and the remote wire connected to the power conn. then it's very possible that it blew the remote turn-on circuit in the amp which would possibly cause the problem. Try hooking it up correctly and see if the amp turns on. As for the previous thread not sure if anyone answered your question but for the remote wire most people run it either off the power ant. conn. from the head unit, sometimes there's a dedicated remote amp turn-on connection, and still some others like to jump the wire off the fuse box and put it to a little toggle switch to be able to turn the amp on that way. But the best way is if the remote connection is available then use it if not use the power ant. wire. If for some reason your head unit doesn't have either connection then go the old fashioned way and use the toggle switch. But hook the amp back up the right way and see if it will turn on. It probably won't as by having the power wire from the battery connected to the remote term. probably blew the circuit out.
Old 02-22-2006, 02:19 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: HELP!! car amp
You should be fine they are both 12V signals. Wire it correctly and try again if not come back...... Nothing would have blown up like cherokee said..... once again they're both 12V.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-22-2006, 03:29 PM
Re: HELP!! car amp
Thats what i was thinking that thier both 12v, and that the remote was in the power terminal, and was getting shut off everytime the car went off so i donno! but i did hook that amp p in my car and it came on but the red light came on really bright and then went to the green one and then it dimmed, but stayed on, so i donno once i start drivin my car again well see!!!
Old 02-22-2006, 09:29 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: HELP!! car amp
it wouldn't hurt anything, but how did you stuff the power wire into the much smaller turn-on connector ?
Old 02-22-2006, 09:35 PM
germanyt germanyt is offline
Re: HELP!! car amp
thats what i was thinkin, most amps have much smaller terminals for the remote wire. unless its 8 awg power and ground, then the rem terminal might be the same size
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 02-22-2006, 09:56 PM
Re: HELP!! car amp
their all the same size!
Old 02-23-2006, 09:07 PM
Audio Guy
Re: HELP!! car amp
must not be a very powerful amp ....... PG is nuts about oversizing the power wire. They pretty much commanded me to use 4 Ga wires on a 75X4 watt amp.
Old 02-23-2006, 09:48 PM
Re: HELP!! car amp
Its a m44 pheonix gold amp, which ive heard are better than most amps, dont know the exact watts
Old 02-24-2006, 01:15 AM
Re: HELP!! car amp
and i do have a 4 gauge wire
