Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-21-2006, 05:58 PM
crabby760 crabby760 is offline
Problems Help!!!
today i realized i am missing a bolt that connects the rear bracket to the tranny.... and also 1 bolt that goes from the tranny to the block
i tried replacing the bolt to that rear bracket but seems as if the hole on the tranny i sstripped.... i had a new bolt and it will not tigten just strips....
any ideas on what i can do to possibly fix this problem...
please don't say NEW TRANNY
Old 03-21-2006, 11:55 PM
klippersr klippersr is offline
Re: Problems Help!!!
to do it right, install a heli coil in metric which is available at auto parts stores, and use original size tranny bolt. There not hard to install.
Old 03-22-2006, 08:27 AM
hxgaser hxgaser is offline
Or you can rethread the hole by using a tap and die set
Old 03-23-2006, 12:51 PM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
use a tap and die and rethread, helicoils dont always hold up and can fall out if not properly done right
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
Old 03-23-2006, 01:59 PM
Your absolutely right if heli coils are not installed right, they might give you trouble. If person reluctant or does,nt have experience and not confinant using these, should use retapping to larger hole, which is easier. I utilize heli coils and have,nt had a problem. I did,nt realize you wanted the quickest fix, and should have mentioned both methods, Sorry.
