Old 02-21-2006, 01:22 PM
germanyt germanyt is offline
Box tuning?
I know this question has been asked before but I'm looking for a website that gives accurate port dimensions. Also, how to you measure the port? LxWxH? I need to figure out the port dimensions for 31Hz in ~8 cubes. Width is about 37", height is about 17", and depth about 26". It's about half MDF and half glass so figuring out the exact volume is difficult since the box cannot come out of the car. Thanks for any help.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 02-21-2006, 01:57 PM
Re: Box tuning?
I found a page on caraudio.com. I hope its accurate.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-21-2006, 05:35 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Box tuning?
WinISD is as actuate as you will need.
Old 02-22-2006, 02:26 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Box tuning?
8 cubes net after all displacements including driver and port? If so go as follows.
6 3" ports 12.6" long each
8 3" ports 17.5" long each
10 3" ports 22.5" long each
12 3" ports 27.4" long each
4 4" ports 14.6" long each
6 4" ports 23.4" long each
8 4" ports 32.2" long each
10 4" ports 41.0" long each
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-22-2006, 05:43 PM
Re: Box tuning?
Where did that info come from? Also, how about slot ports. A single 16" x 4". What would the depth be for 31 Hz for 7, 7.5, and 8 cubes, excluding driver and port displacement (exact volume is still undetermined)?
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-22-2006, 05:49 PM
Re: Box tuning?
make that 15 inch tall x 4 inch wide
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-22-2006, 07:29 PM
Re: Box tuning?
Also, I'm not sure I understand how you did this figuring in port displacement. Let's say my box is 7.5 cubes. The driver displacement is .36 cubes. So I'm at 7.14 cubes. To tune a 7.14 cube box to 31 Hz requires a certain size port. So I use 7.14 cube port dimensions. If port displacement needs to be accounted for, my 31 Hz port has changed my box from 7.14 cubes to roughly 6.5 cubes. Since the enclosure is smaller due to displacement, the port size is now not correct because it was calculated based on a 7.14 cube box. Should I just assume that the box will be roughly 6.5 cubes with port and driver displacement and port based on that volume? If I tune based on 7.14 but port displacement makes it ~6.5 then my tuning freq changes from 31 Hz to about 29.6 Hz. How much would 1.4 Hz change the sound? And does this post make sense? Sorry if it doesn't.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-22-2006, 09:00 PM
Re: Box tuning?
somebody plz help quickly, i have to get these dimesions tonite. ng, fry, stang, where ya at?
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-22-2006, 10:13 PM
Re: Box tuning?
things have changed, its actually 6.64 cubes without displacement so ill have to figure that out. should i tune higher to make up for lack of volume or staple cotton to the inside of the box?
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-22-2006, 11:46 PM
Re: Box tuning?
well, the decision was made. since the subs are only 2 inches apart and there isn't much room above or beneath them, a slot port was pretty much ruled out. my favorite next to the slot was 6 3 inch ports 16.74 inches deep. three on top and bottom in a triangle patter low and upside down triangle high. the other option, to reduce port displacement as much as possible is two 4 inch ports, 8.3 inches deep or even 2 3.5 inch ports 6.03 inches deep. they seem awful small but i guess that is how it works.
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
Old 02-23-2006, 09:30 AM
Re: Box tuning?
COMPLETELY stuff that bitch with as much polyfill as you can get in it without Blocking the polevents and ports to get them up closer to 8 cubes NET.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-23-2006, 11:25 AM
CBFryman's Avatar
Banned
Re: Box tuning?
doesnt work that way with ported enclsoures.
Old 02-23-2006, 11:29 AM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Re: Box tuning?
So are you saying polyfill doesn't work in ported boxes CB?
Old 02-23-2006, 12:08 PM
Re: Box tuning?
yes it does dipshit. It slows down the waves hence making the box sem bigger. My AV18's box changed when I just lined it with polyfill. It makes the box seem bigger, lowers the tuning, and helps the low end out a little bit.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-23-2006, 12:35 PM
Re: Box tuning?
does it matter how large the port is as long as it is still the right tuning freq? what i mean is, a 6 inch long port seems awfully small will it still work the same as a larger port of the same freq?
1 Optima red top
Big 3 (1/0 awg)
Infinity Kappa 6x9s
MTX Thunder 3404
