Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 02-21-2006, 11:29 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
What's needed for a 6'' lift?
I want to put on springs that raise my 2002 Wrangler X atleast 6''. It is currently raised 3'' - 4'' with some shocks for that lift... which I think might be good enough for 6''. What else would I need for this 6'' above stock lift? What about the drive shaft? Transfer case drop, or slip yoke eliminator etc.? Basically I want to get everything right (or as close as possible) on the first sweep of installs. Please give any and all advise. Thanks
Oh yeah, I'm doing a 1'' - 2'' BL as well. Let me know what to expect, and how to avoid problems! ...Both cheap and the best options. Thanks.
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 02-21-2006, 01:13 PM
Ray H Ray H is offline
Re: What's needed for a 6'' lift?
For 6" of lift, the best solution, and as far as Im concerned, the only solution is a long arm kit. There are several types of long arm kits available now; three link, four link and radius arm kits. The long arm kit acomplishes two things, it increases the arc radius of the suspension as it travels up and down and it lessens the control arm angle. Do an experiment, put a jack under your bumper and raise the Jeep to the 6" height then look under at the control arm angle, now imagine how the axle will move forward as the suspension compresses, no doubt your ride and handling will suffer with that much lift and short arms. Now check out your steering linkage and imagine what will happen to your toe as the suspension goes through its movement.
Some of the items you will need to take into consideration at that height for a decent performing Jeep are longer and adjustable control arms both upper and lower and front and back adjustable trackbars with a drop bracket, drop pitman arm or crossover steering, extended brake lines, longer swaybar links, SYE and long travel CV rear driveshaft, maybe an extended front driveshaft depending on your suspension setup.
Its not a cheap proposition to go beyond the design limits of the stock suspension. Of course you could just throw some taller springs or spacers on there and be done with it but dont be surprised if the performance, handling and ride of your Jeep goes in the crapper.
Old 02-23-2006, 01:27 PM
Kuhn's Avatar
Very helpful... I'll start saving!
'98 Eclipse RS
Old 02-23-2006, 07:09 PM
gutlass gutlass is offline
lets not forget the rear upper ajustable control arms and shoch relocation brackets in the rear! you will be needing alot of money to go that high man! also you say you have a wrangler X? you best be sure that you have the dana 44 rear axle or dont even think about doing it! the best way to tell is to look at your rear pumpkin and if the fill plug is rubber its a dana 35(dont want larger than a 32 in tire) and if the plug is metal you have a dana 44 and prob dont want to go larger than a 35 in tire! you should do a ton of research before you get into a 6 in lift cause if you dont know what your doing you will have a lot of problems I promise you! you would be best off researching on www.jeepforum.com
