Old 02-21-2006, 10:23 AM
Busa-Rush Busa-Rush is offline
staining brass
I have just made some nice leaf springs for my 1/8th scale pocher alfa in brass. I seem to rem on here some while back about a chemical that would stain brass to a black clolor?.. painting them would be no good really as they are all seperate parts that bolt together and would chip on assembley..
thanks in advance
dave.c
Old 02-21-2006, 11:43 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Re: staining brass
I haven't used it, but I think you are talking about "Blacken It"... - Mark
Old 02-21-2006, 01:40 PM
Re: staining brass
that's the stuff!! cheers mark
dave
Old 02-21-2006, 06:09 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: staining brass
I was actually fixin' to ask about this same stuff, and what metals it worked on, because it would be killer for blackening PE mesh, instead of painting. We all know what a PITA it is to paint mesh, when the paint all gets into the holes and junk.
Old 02-22-2006, 04:12 AM
klutz_100's Avatar
Re: staining brass
Willimo - Blacken it is basically Selenic acid, (from wikipedia: H2SeO4, is an oxygen acid of selenium. Selenic acid is analogous to sulfuric acid and has similar properties; however, it is a stronger oxidizer.)
Old 02-22-2006, 05:29 AM
klutz_100's Avatar
Re: staining brass
Aslso check out the Chronos site at http://www.chronos.ltd.uk/acatalog/ and search for Carrs products - it will give you some more info, at least.
Old 02-22-2006, 06:00 AM
sjelic's Avatar
sjelic sjelic is offline
Re: staining brass
Sorry to interoupt but I have looked at the link and saw that different solutions work on different metals. Since I allready came out stupid with this last sentence I may do it again, what is white metal made of (soldier, iron, Pb (don't know English word, this is chemical sign), or something else) and which acid would eork on it (white metal).
Sasa Jelic
SCALEMAKERS
Old 02-22-2006, 06:09 AM
klutz_100's Avatar
Re: staining brass
White metal: Any of various whitish alloys, such as pewter, that contain high percentages of tin or lead.
Also: http://www.caswellplating.com/kits/metal.htm
also
Blackening of white metal
Jul 19, 2001
I want to blacken white metal. Is there any chemical to blacken it?
Ajay Singhvi
Ases Chemical Works - Rajasthan, India
Jul 24, 2001
If you are talking about white metal as in pewter that is mostly tin there is a chemical oxidising process that is made up with nitric acid 5% by volume and copper sulphate 1/3 oz/gal (oz av & US gallon. Parts are simply immersed until the darkness required is achieved then rinsed abd dried.
Old 02-22-2006, 06:11 AM
klutz_100's Avatar
Re: staining brass
http://www.brushplate.com/plating_chemicals.htm
