Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-21-2006, 09:46 AM
Scaramanga Scaramanga is offline
Checking Codes 1995 Suburban
Is there an easy way to check codes? It seems to have an ODB I like my Lumina, and I can check the Lumina's codes with a paperclip. Can this be done the same with the Surburban? The connector looks the same, but has about 3 holes that have metal in them, where my Lumina doesn't. Anyone know? Thanks!
Old 02-21-2006, 10:25 AM
maxwedge maxwedge is offline
A990 racer
Re: Checking Codes 1995 Suburban
Must be transitional obd11, if so you will need a real scanner to do this.
Old 02-21-2006, 12:45 PM
2000CAYukon 2000CAYukon is offline
http://www.troublecodes.net/GM/
If this does not work, then you will need a OBDII code reader (like maxwedge said). I have read that some of the late 95 models were actually OBDII but had OBDI connectors.
//2000CAYukon
Old 02-21-2006, 07:20 PM
Thanks for the link! Just wondering if jumpering the A&B terminals could damage anything if it does not work.. I just don't want to fry the computer or something else.
Old 02-27-2006, 01:26 AM
Anyone know?
Old 02-27-2006, 01:18 PM
Originally Posted by Scaramanga
Anyone know?
A is ground and B is the test terminal. This fill not fry your computer. If you have ever had your Suburban Smog'd, when they hook up the scanner, A is connected to B.
//2000CAYukon
