Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 02-20-2006, 10:40 PM
geofrog geofrog is offline
Send a message via MSN to geofrog Send a message via Yahoo to geofrog
Shifter Needed
Hello, I own a 1994 Geo Tracker, THe spring on the shifer broke, (manual Tranny) THe spring cant be replaced, however I can replace the entire shifter, which is everything that comes out of the shifter box, on top of the transmissiong.
What I need, is someone that is parting out their tracker, or suzuki, and is willing to sell me the shifter, for a great price$$$.
Thanks,
Kris
Old 02-21-2006, 10:25 AM
viperh viperh is offline
Send a message via AIM to viperh Send a message via Yahoo to viperh
Re: Shifter Needed
If a spring is broke why can't you go to a hardware store and buy another one for a buck or less?
Old 02-21-2006, 11:54 AM
Re: Shifter Needed
The spring is just an ordinary spring, it is more cylone shaped, and the spring cant be removed off the stick shift, without damaging the spring.
I thought about that myself.
Another thing, I found one at a junk yard, but they wanted 50 bucks for it, NOT WORTH IT. I will deal with the inconvienence of not being able to easily shift into reverse, and an extremely loose feeling shifter.
Old 02-22-2006, 11:26 AM
Re: Shifter Needed
Wow you have struck my curiosity I'm going to tear my shifter apart when I finish re-upholstring my seats to see if I can't think up a way around it for you. Give me a day or two to post back. This is on the Transmission shifter and not the 2wd to 4wd right?
Nate
Old 02-22-2006, 01:03 PM
Re: Shifter Needed
Thats right, It is on the actual shifter, right between the nuckle and the retainer.
Old 05-03-2007, 09:16 PM
jtgh's Avatar
jtgh jtgh is offline
Re: Shifter Needed
where?
i see 2 side springs, 1 reverse spring.
and 3 detent pins for the shift rails.
any spring can be replaced!
compression or streatch type?
diameter, and length.? all easy.
force is the hardest to match so guess.
to bad no images can be attached, rats.
well , howbout this.
I have a full factory tranny manual. I am blessed.
excerpt:
http://www.jhodson.net/tracker/shift.JPG
91 GEO TRACKER , & others. Restoring.
