Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-20-2006, 10:17 PM
ndaniel7 ndaniel7 is offline
What radio will work?
I have a 2000 Jeep GC and I only have the tape deck and now a days you need atleast a cd player. And I don't want to go all fancy I would just like a cd player from another jeep they sell them on ebay but how do I know which ones will work in my jeep. Some say that they will. What would guys suggest?
Old 02-20-2006, 11:57 PM
Bob D. Bob D. is offline
Re: What radio will work?
There is difference in the connector-it changed in 2001.
There is also a multiplicity of Grand Cherokee head units.
From another site:
"DaimlerChrysler manufactures an incredibly wide variety of radios for their different vehicles, many of which look very similar and have the same sales codes, yet may have small differences in features. When replacing a factory radio with another factory radio, it may be important to try and find the correct model made for your Jeep. For example, some Chrysler radios have the clock display defeated in vehicles that have a separate clock in the dash. Also, due to preprogrammed audio equalization levels that are programmed into the vehicle's body control module, if a signal from the radio is not recognized by the BCM (Body Control Module), the unit will default to a flat curve. Combined with various levels of speakers used from model year to model year, the sound quality of the audio can be reduced."
But I would still try to stick with Chrysler head units.
It could be as simple as getting one with the same connector.
Make sure you have a return policy if it does not work.
Old 02-21-2006, 06:49 AM
BenBB BenBB is offline
Im pretty sure that even if you get a different chrysler head unit or go and get an aftermarket one, there is always converters for the units. If the wiring is different you can do it yourself or if avaliable, there are quick connectors that go from the head unit to the jeep wiring harness, only like $15.
Old 02-21-2006, 09:17 AM
legalfee legalfee is offline
I'd check E-Bay. Just do a search on Chrysler Stereo. Just look at the pictures and make sure it will mount in your dash and the back connectors match what you have. I had a AM/FM Cassette CD that went bad and I wanted a CD changer but wanted to stay with a Chrysler to keep the steering wheel controls. So I bought a AM/FM Cassette with CD changer controls and got an Alpine CD changer and adapter at Circuit City. I've been very happy with this setup.
Old 03-02-2006, 02:37 AM
kru kru is offline
The plug didn't change until 2002. www.replacementradios.com has several factory original radios for that vehicle. Here is one that is brand new and is plug and play:
http://replacementradios.com/product...products_id=41
Old 03-04-2006, 05:42 PM
a_alyte a_alyte is offline
Buy from www.crutchfield.com, they give you everything you need, harness, life time tech support etc. You can enter your vehicles info. & they'll show you only the radio's that fit your vehicle. They also have a great 30 day money back guarantee (no return shipping cost). Once you put your order in, you'll have your merchandise within 2-3 days!
Old 03-06-2006, 07:02 PM
kru kru is offline
Crutchfield sells aftermarket. ndaniel7 was asking about factory radios. That's why I pointed him/her to www.replacementradios.com
Crutchfield is just as good a choice as any for aftermarket radios but many people don't want to mess with an aftermarket radio. They don't look right in the dash, are harder to operate, require mounting and wiring adapters and get stolen more often.
If you're not trying to rattle the glass and/or entertain people 2 blocks away, the factory original units are more than adequate. A simple speaker upgrade will often suffice if a person desires a little better sound. And that can be done without any of the negatives of the aftermarket radio installations...
My 2 cents...
Old 03-09-2006, 12:38 AM
2 Cents appreciated!
It's just a matter of opinion mixed w/personal taste, I guess!
Old 03-09-2006, 07:58 AM
bringselpup's Avatar
bringselpup bringselpup is offline
Use those sites to get model numbers of what will fit. Then you can start hitting the net and try to hunt up a deal. I know I didn't have to deal with anything fancy like controls on the steering wheel but what I did was look at those sites that told me what would fit and then start hitting Ebay and other places hard. An older model Jensen CM715K was a perfect fit and some places still had them for over $100. I found one for $50 and Pep Boys had the connector for $15. Because it's a 1 1/2 DIN unit it still looks like it belongs there.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
