Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 02-20-2006, 08:34 PM
daboone daboone is offline
security system troubles
In the last week my security system on my 95 conti is cutting out the starter. The remote opens the doors and trunk, it locks the car but I can not start it all the time ( four times in the last week it cut out on me). When you press the unlock button on remote the door opens but you get no chirp from the alarm. The valet switch says the system is disarmed. I insert the key, turn the ignition on and press the override switch and try to start the car but nothing happens. I eventual get it started by using the overide switch but it takes 20-30 minutes of playing. Any thoughts on why? Can I some how bypass the security system for the starter? Is there some time deley to reset the system? I do not really care if the car is armed. The battery is new. The starter seems to be fine, Starts right up when it gets power. With the starter cut out nothing happens when you turn the ignition switch.
I could really use some insight on this security system if anyone has any info to share on this.
Thanks
Daboone
DaBoone
Old 02-20-2006, 09:09 PM
Towncar's Avatar
Towncar Towncar is offline
Re: security system troubles
Was this a factory install?
I wasn't aware of a remote start option in 1995.
In any case, it sounds like whatever remote start module you have, it's on it's last legs. Could also be the installer didn't secure the connections properly.
-Steven
1996 Town Car, Cartier
Old 02-22-2006, 09:24 PM
There is no remote start on this car. What I meant was I used my keyless remote to open the doors which disables the security system so that the starter is able to come when the key is turned.
What I am trying to find out is if there is someone out there who knows how to disable the security system. I do not care if I have the security alarm or not. I would rather know that when I turn the key my car will start.
Any help???
Daboone
DaBoone
Old 02-22-2006, 11:26 PM
Towncar's Avatar
Dang, the system is a monster. Here's a guide to what your up against. I don't see any way to kiil the system.
Did you ever get that Factory Sevice Manual from fordcds.com? All these processes are in there.
PINPOINT TEST C: ALARM SYSTEM DOES NOT ARM OR DISARM PROPERLY
² C1: TEST ANTI-THEFT INDICATOR
² C2: TEST COURTESY LAMPS
² C3: COMMAND ANTI-THEFT INDICATOR
² C4: TEST ANTI-THEFT INDICATOR CIRCUIT
² C5: TEST ANTI-THEFT INDICATOR OUTPUT
² C6: TEST IGNITION CIRCUIT
² C7: TEST PASSENGER DOOR AJAR
² C8: TEST DRIVER DOOR AJAR
² C9: TEST ARMING WITH DOOR LOCK SWITCH
² C10: TEST ARMING
² C11: TEST DRIVER DOOR AJAR TRIGGER
² C12: TEST KEYLESS ENTRY DISARM
² C13: TEST DISARM WITH KEY
² C14: TEST ARMING WITH KEYLESS ENTRY REMOTE TRANSMITTER
² C15: TEST HOOD TRIGGER
² C16: TEST DISARM WITH KEY IN DRIVER DOOR
² C17: TEST DISARM WITH KEY IN PASSENGER DOOR--DRIVER DOOR DOES NOT STOP ALARM
² C18: TEST PASSENGER DOOR TRIGGER
² C19: TEST DISARM WITH KEY IN PASSENGER DOOR--DRIVER DOOR DOES STOP ALARM
² C20: TEST HOOD ANTI-THEFT CONTROL SWITCH
² C21: TEST HOOD SWITCH
² C22: TEST GROUND
² C23: TEST DOOR LOCK CYLINDER SWITCHES
² C24: TEST DOOR LOCK CYLINDER SWITCH WITH KEY IN LOCK
² C25: TEST SEAT OCCUPIED CIRCUIT
² C26: TEST HOOD SWITCH CIRCUIT
-Steven
