Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-20-2006, 08:16 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
output shaft seal?
im praying that leaks due to the output shaft seal's is a common issue so others can tell me if this is a hard task to take on... i pulled drive axels out of 88 civic hatchbacks, is it the kinda the same on a 92 GS?
Old 02-20-2006, 11:14 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: output shaft seal?
you have to seperate the ball joints, take half shaft nut off, take out shaft and pry out seal, tap new seal in, repeat on other side...
Old 02-21-2006, 11:03 AM
EDMUND65's Avatar
W/Two Wheel Drive
Fig. 25 Wheel Bearing Support Tool Installation
CAUTION: Do not apply vehicle load to the wheel bearing after removal of the driveshaft. If a load must be applied to the bearing, temporarily secure with special tool No. MB990998-01 or equivalent.
  1. Loosen drive axle nut, then raise and support front of vehicle and remove wheel and tire assembly.
Fig. 26 Ball Joint Removal From Steering Knuckle
  1. Using special tool No. MB991113-01, disconnect lower arm ball joint from knuckle.
Fig. 27 Tie Rod Removal From Steering Knuckle
  1. Using special tool No. MB991113-01, disconnect tie rod end from knuckle.
Fig. 28 Driveshaft Removal From Front Hub
  1. Press driveshaft from hub using shaft puller No. MB990241-01.
Fig. 29 Driveshaft Removal From Transaxle Case
  1. Insert a suitable pry bar between the transaxle case and the driveshaft, and pry the shaft from the transaxle. CAUTION: Do not pull on the shaft, as damage to the joint may result. Pry bar should not be inserted too deeply, as damage to the oil seal may result.
  2. Reverse procedure to install. Lower vehicle, and tighten knuckle to lower arm ball joint nut, and torque axle nut to 188 lb-ft , maximum.
