Old 02-20-2006, 08:12 PM
transgta transgta is offline
Exclamation Its Not A Lifter Its The Flywheel
Just Finally Tracked It Down To Flywheel.when I Popped Off The Little Rubber Plug To Get A Visual Could Hear It And Theres Little Marks On The Slick Part. The Marks Are Almost Exactly The Same All The Way Around. Are These Marks Normal And Any Ideas On The Ticking Noise.the Ticks Are To Revolutions Of Motor. Dave
Old 02-23-2006, 08:21 PM
Re: Its Not A Lifter Its The Flywheel
I took the little front cover off checked all bolts for tightness and tried to check for a crack. Nothing but i would sure like an idea anybody ever heard of this?
Old 02-23-2006, 11:43 PM
unclebubbles unclebubbles is offline
Normally a loose/cracked flywheel/converter would make more of a knocking sound than a ticking, and would tend to dissapear when you put it in gear. And those sounds are sometimes intermittent and not in time with the rpm. If it is the exhaust, like you said in an earlier post, you could tell by putting it in gear, locking the brakes, and gas on it. If its exhaust it should get louder. You could try partially blocking the exhaust and doing this too. If you have a stethescope, or the old iron rod or long screwdriver trick, you can listen around on the engine, pinpoint the noise, and tell if its exhaust or not. You wont hear the exhaust through the scope, or the rod. Good luck.
Later
Ed
PS: you got me curious about the marks on the flywheel, id have to see that?
