Old 02-20-2006, 06:41 PM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
Motor
http://us.f540.mail.yahoo.com/ym/Com...ead=&box=Draft
Hopefully if this works, this is my motor, does anybody know where i could put my battery? or does anybody know were i could get an intake that would work for this setup??? thanks
Old 02-20-2006, 08:13 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Motor
link dont work,
your giving a link to the inside of your email.
In the process of B00stin my D
Old 02-21-2006, 10:34 PM
91S10's Avatar
Re: Motor
well how do i put pictures in my post then?
Old 02-22-2006, 11:37 AM
pokey69 pokey69 is offline
Re: Motor
www.photobucket.com
Old 02-22-2006, 01:55 PM
91S10's Avatar
Re: Motor
Ok heres my Motor
Old 02-22-2006, 02:35 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: Motor
not to be a jerk or anything but the valve cover only has about 4 bolts in it. maybe next time you should take it off. but that was a good paint job besides that.
Old 02-22-2006, 05:11 PM
2poor2tune's Avatar
Re: Motor
personaly i would just go to ebay for an intake. but dont go cheap cuz then you dont get the right fit. remember you get what you payfor. and for the battery situation. just throw it in the back. go to autozone or checker auto parts and buy a battery relocation box. then get some 4 guage amp wire. run the wire to the starter and the fuse box up front(under the hood) and connect it to the battery. for the ground i just scraped away some of the paint around one of the tail light bolts and connected it there. good luck for future mods tho.
Old 02-22-2006, 10:01 PM
91S10's Avatar
Re: Motor
Thanks for the advice, and not to be a jerk back but i didnt paint it, the guy that had it before me did
Old 02-22-2006, 11:03 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: Motor
yeah that's a bad paint job, but I don't know why you want to relocate your battery?
Old 02-23-2006, 08:28 AM
91S10's Avatar
Re: Motor
So that i could put a cold air intake on my car unless you know were i can get one for my car with the battery like that??
Old 02-23-2006, 12:08 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Motor
you shouldnt need to relocate your battery... if you get one for your car (it will say for 88-91 civic/crx...ect) it will go around your battery i know someone here has a pic of a cold air with stock battery location...check out the pic (roll call thread) in off topic.
here is a pic of my short ram...i got it at auto zone (for a 92-00 civic) it didnt fit too well so i cut it a little put it on my stock air tube and it works fine for me.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 02-23-2006, 12:35 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Motor
I have a CAI with my battery in it's stock location. I don't have the stock battery tie down though so I just got one from Advance Auto and tied it down across it instead of long ways. My pic should be in that pics thread as described above...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-23-2006, 07:05 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: Motor
I know about the horrible location of the battery all too well...
Had just installed my CAI and not even a day later, from touching the battery terminal it ate a hole straight thru it... So I just taped it up with tape like this...
Note the new red cover on the terminal, I ended up buying an OEM battery cable to fix the problem... Havnt had a problem since... The aftermarket terminals are just way too big... Anyways, when you install it, just becareful, move it back and forth to make sure it wont touch the batt + terminal.. Course I have since cut off the peice where the tape is, and just made it into a short ram... So the silicone coupler is there by the battery now to stop it from happening as well...
Old 02-23-2006, 07:11 PM
91S10's Avatar
Re: Motor
Ok cool, thanks now another ?, Since i have an 89 CRX 1.6 si motor instead of the 1.5, would i buy an intake for the 1.6 CRX or the 1.5 Civic?
Old 02-23-2006, 11:36 PM
2poor2tune's Avatar
Re: Motor
im pretty sure they are the same thing. but it might be just me.
