Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-20-2006, 04:58 PM
eclipser2001 eclipser2001 is offline
strut bar test
how would i test my car's performance before i install the back and front struts? if that badly worded: you would dyno your car before you put a turbo on it, then dyno it again. that same consept but with strut bars.
Old 02-20-2006, 05:09 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: strut bar test
g-meter... iono where you get them or how to, but you can do it like that... as in
.67 lateral g
1.00 lateral g
Don't act like you don't love it.
503/2000
Old 02-20-2006, 05:24 PM
808drifter 808drifter is offline
Re: strut bar test
go race it around some turns then install the bars after the cars steering should feel more heavy and presice.
Old 02-20-2006, 05:25 PM
Re: strut bar test
would i even need the front and back both? or just one or the other?
Old 02-20-2006, 05:26 PM
Re: strut bar test
get both bars if you can.
Old 02-20-2006, 05:28 PM
Re: strut bar test
well, what does one do that the other doesn't?
Old 02-20-2006, 05:33 PM
Re: strut bar test
one only stiffens the front one only stiffens the rear.
Old 02-20-2006, 05:38 PM
Re: strut bar test
ok, i'll do that then. should i get rear ones on http://www.roadraceengineering.com/3gsuspension.htm (bottom of the page) or get some different ones?
also anti-sway for an rs yay or nay?
Old 02-20-2006, 05:44 PM
Re: strut bar test
yes get them both.
Old 02-20-2006, 05:55 PM
Re: strut bar test
RECAP: front and rear strut, YES
anti-sway, YES
...will do.
Old 02-20-2006, 06:08 PM
Re: strut bar test
should the front struts be a easy to install than the rear ones are?
Old 02-20-2006, 09:31 PM
Boogy886's Avatar
Boogy886 Boogy886 is offline
Re: strut bar test
A front anti-sway bar would increase understeer...right?
Old 02-20-2006, 09:35 PM
Re: strut bar test
would i get front or rear anti-sway? sry if noob question
Old 02-20-2006, 09:52 PM
Re: strut bar test
if i get the front and rear strut bars, will the performance difference be dramatic or will i barely notice them?
Old 02-20-2006, 11:41 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
Re: strut bar test
yep
