Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-20-2006, 04:39 PM
SRcH4aReSN SRcH4aReSN is offline
fuse box question... and other question
ok i got a couple questions.
1.) on the fuse box there is a hole labeled "pwr" and to my understandig, anything plugged into this hole will get power, even when the car is shut off. should there be anything plugged into this? theres 2 wires plugged into this, and im woundering if that could be the reason for my battery dying.... (im having a lot of trouble with the battery and alternator)
2.) the oil/choke light came on. what does it mean and how do i fix it?
3.) heres a question about the alternator.
let me explain the picture. theres a wire that goes from the battery to the alternator, and thers a plug that goes from the alternator to who knows where. i've been having trouble with my car staying charged, and i took it to autozone and this is how the guy told me to hook it up ( so my alternator would put the battery to 14+ volts while the cars turned on. he said cut the wires that plug into plug, merry them, and run a wire from them to the battery. i did that, and when the cars on, my battery is running at 14 volts or so. is this ok?
this is getting frustrating.
Old 02-24-2006, 12:57 AM
Re: fuse box question... and other question
Old 03-17-2006, 10:04 PM
Fifty Thousand Fifty Thousand is offline
well the oil/ choke lgiht means your either out of oil or the choke is sticking open or closed
