Old 02-20-2006, 12:44 PM
gstnewb gstnewb is offline
Is this fluid any good???
My shifter has been having some problems while cold. I get the 1st-2nd weird noise when shifting. I am pretty sure it's time for a new fluid. I did some search and I found this Royal Purple Syncromax Fluid from dsmparts.com.
Do you have any tips for using this fluid or it's just a direct replacement? The car is a 1g gs-t with 160k miles on it.
Old 02-20-2006, 12:46 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Is this fluid any good???
I've honestly never heard anything bad about the royal purple line of products, but i can't say that i've heard about this fluid, i'm sure you can do some google searches and research it a little bit if you can't get any answers here.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 02-20-2006, 12:47 PM
Yeah, i did some search but the results I got were general for all Royal purple fluids and they were all good. I am just more curious if I should mix it with anything so I don't get any leaks?
Old 02-20-2006, 12:52 PM
stangbuster stangbuster is offline
Send a message via MSN to stangbuster
I have used Royal Purple motor oil in my k5 blazer with a 406ci, but only in the summer, 50 weight doesnt work well in winter in Iowa...Wonder why? haha...
Anyway, Royal Purple is all the rage around here in anything high performance...
The other one to look at is Redline oil products...Never tried them but hear good things...
GOOD LUCK!
Old 02-20-2006, 12:55 PM
I already ordered 3 bottles of this fluid for $27.99 total. I am just worried about some leaks since I read in an earlier post about someone putting some of the syncromesh fluid and getting leaks from his axle seals, IIRC. I hate leaks and certainly don't want any to deal with
Old 02-20-2006, 01:04 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
thast why you install new seals.. 2.99 from pepboys, a large screwdriver and 20 min if you have your half shafts out! problem solved
Old 02-20-2006, 01:16 PM
Is it that easy??
Old 02-20-2006, 01:59 PM
I guess I will see if I need to replace those once I change the fluid
1990 Eclipse GS-T (STOCK)
Planned mods: 15 psi boost; turbo timer; blow-off valve; 3" catback exhaust; alum. IC pipes.. for now
Old 02-20-2006, 02:04 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
u gota take ur axels out to change ur fluid anyway so i would change ur seals why ur at it
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-20-2006, 05:57 PM
Really? Boy, you can tell I have never done that before. I rebuilt a whole 87 vw golf but that car is soo simple compared to this one. I really need to buy me a manual. Any suggestions on what's the best when it comes to manuals??? Hanes, Chiltons,..?
Old 02-20-2006, 11:25 PM
-Josh-'s Avatar
Chiltons
AF User Guidelines
Old 02-20-2006, 11:29 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I agree my haynes manual is used only as low grade toliet paper.
1991 GSX 2.3 Stroker
Old 02-21-2006, 01:10 AM
Chiltons it is then . Thank you all for everything. It's so good to have these forums to go to and learn so much stuff for free .
