Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-20-2006, 12:38 PM
billindelicato's Avatar
billindelicato billindelicato is offline
I keep blowing fuses
97 rodeo dashboard and running light fuse keeps blowing every time i replace the fuse. i have checked the wiring diagram and nothing else is associated with that fuse line but yet i keep blowing them...any suggestions? i even went so far as to up the fuse blows them too
1998 Chevy Blazer LS 4x4
1996 Ford Dunderbird LX 3.8L
Old 02-20-2006, 01:05 PM
directory's Avatar
directory directory is offline
Re: I keep blowing fuses
it could be a pinched wire. have you done any work under the hood recently? are they factory running lights? did you install them? i'f start with the light, then follow the wire back. eventually you are going to see the issue.
wire rubbed through, cut, prematurly grounded out...something like this is along that wire somewhere...
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 02-20-2006, 01:10 PM
all i did when it started happening was change out the bulb in the right rear tail light everything is original in the truck otherwise made no mods to the lighting
Old 02-20-2006, 01:19 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Have you removed that bulb?
2000 VW New Beetle TDI
2007 Honda CR-V
Old 02-20-2006, 01:34 PM
yes i have removed and replaced with another type of bulb (different manufacturer) still blowing
Old 02-20-2006, 01:51 PM
directory's Avatar
it may be possible that you are pinching a wire inside the housing --or with the housing.
remove the housing again like you are changing the bulb--then replace fuse. try that--leave the housing out while testing.
SKYWARN
we be clubbin'
--B
Old 04-05-2006, 01:28 PM
95 Rat 95 Rat is offline
Send a message via AIM to 95 Rat
This was happening on my Rodeo as well. It turns out it was one of the front turn signals/running lights. The socket that the bulb goes into was very rusty and wasn't water tight. I actually couldn't even remove the bulb. Got a new light for $20 off of ebay and haven't blown a fuse yet.
Old 04-05-2006, 05:52 PM
Ramblin Fever Ramblin Fever is offline
Do you have a trailer wiring harness?
If so, remove it, replace the fuse, and see what happens.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 04-05-2006, 08:38 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
I have seen many of these
follow the wiring from the bulb back to where it goes through the center support it usually shorts out there
it is also possible the short may be under the radiator there is a harness the=at runs under it
