Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 02-20-2006, 11:27 AM
sunny16888 sunny16888 is offline
03 towncar keyless entry module
any1 knows where the actual module for the keyless entry is for the 2003 towncar? I need the numbers to open the doors. I checked the whole trunk for the number and nothing there , seems like the last owner took off the sticker, so if any 1 knows , it will be appreciated.
Old 02-20-2006, 07:14 PM
DriverBill's Avatar
DriverBill DriverBill is offline
Re: 03 towncar keyless entry module
I just found mine (module) inside the driver door behind the finish pannel. I have a '96 so it may not be the same.
The combo number should be on a sticker stuck to the side of the trunk hinge. Again, that's where it is on my '96.
Hope this helps.
DriverBill
'92 Lincoln Cartier (Rest In Peace),
'96 Lincoln Signature
'66 El Camino (Days Gone Bye)
'79 El Camino
Old 02-20-2006, 09:04 PM
Towncar's Avatar
Towncar Towncar is offline
1996 and 2003 ID's are in the same locations.
The system's permanent entry code is located in four places:
l on the owner's warranty card.
l on a label on the inside of the luggage compartment door hinge.
l on an owner's code card.
l on the driver door module.
-Steven
1996 Town Car, Cartier
Old 02-21-2006, 10:18 AM
i checked the all the places u guys mentioned but in the 2003 its must be in a new location they put, the module i meant. i had a 85, 90, 96 and now a 03 , this is because im a limo driver. thanks anyways guys
Old 02-21-2006, 12:36 PM
Towncar's Avatar
The Limo may be different -- Ask this question to Dereck at www.LincolnsOnline.com
-Steven
Old 02-21-2006, 05:42 PM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
i didnt read trhe other responses so ya might have amready been said get the delear to read the door code. also this is off topic but this is to town car
towncar do u like live ur life waiting for a new towncar thread so u can asnwer it? because every sincele post has u in it lol
Old 02-22-2006, 10:13 AM
as u can see when i have time i will help some1 with the questions, like every 1 else here , but i dont wait for a question so i can answer it, i dont have that much time at the comp
Old 02-22-2006, 02:44 PM
Towncar's Avatar
Originally Posted by master hec0
also this is off topic but this is to town car towncar do u like live ur life waiting for a new towncar thread so u can asnwer it? because every sincele post has u in it lol
Well, here's the story on that --
I'm on the computers 6 days a week, 15 hours a day.
Thats my job so I have no choice. I have a Town Car, Mazda3, PT Cruiser, Camry, F250, gPZ550, KZ1000, and a boat. The only one's that aren't falling apart are the boat (cause I dont use it much) and the Mazda3 (cause it's only 2 months old).
When anything breaks, or I have a question about something, the first place I go is to the computer, google, and the forums. Lots of folks have helped me through some bad times, saved my countless time and money. Through these processes I've learned tons about these vehicles I own, attained copies of the PC based service manuals, learned even more ---
That means, you'll find me on about 20 other forums too Not to mention Excel, Access, and programming forums.
So, should I keep all that inside -- no way. I owe you folks more than I can ever repay. If answering a question when I know the answer, or directing someone in need to someone in the know helps that person, that makes my day.
That's what it's all about folks -- the internet makes our planet a very small place so lets use it for the purpose it was created.
-Steven
Old 03-03-2006, 07:52 PM
klaymonster klaymonster is offline
Post Re: 03 towncar keyless entry module
What else can you do from those little key pads?
Mine is a 85 Mark VII LSC so your may differ, but after entering your code you can then:
-Unlock the passenger side door (press 3)
-Open the trunk (press 5)
-Lock both doors (press 7 & 9 at the same time)
-Define an aditional 5 digit code (press 1 and then the 5 digit code)
Are there any other tricks you can do i am unaware of?
Old 03-03-2006, 08:10 PM
Towncar's Avatar
Guess you havn't tried this one, maybe not available in 85.
- Enter the OEM code, followed by any user code, don't blink your eyes or you'll miss it, then press 1/2 9/0 simutaneously. The whole car (except for the hood ornament) disappears for a brief moment.
Ford was experimenting with the security system and stealth technology.
-Steven
Old 03-03-2006, 09:23 PM
PantherFan PantherFan is offline
LOL... Quite the technology feat! I wish the FoMoCo guys that did this worked on the 96-2001 intake manifolds.
Thanks for the laugh
Not that this applies, but there also appears to be a TSB on the keyless entry for 2002-2004 LTCs.
Keyless Entry - Door Locks Inoperative Using Pad/Remote
TSB 05-6-7 04/04/05
DOOR LOCKS INOPERATIVE - FUSE 2.30 OPENING INTERMITTENTLY
LINCOLN: 2002-2004 Town Car
ISSUE
Some 2002-2004 Town Car vehicles may exhibit the door locks being inoperative when using the keypad and/or remote keyless entry (RKE) fob. This may be due to a short in circuit 797 causing fuse 2.30 to open.
ACTION
Check Circuit 797 (LG/VT) for shorts to ground. Perform wiggle test and monitor DVOM. Potential areas for shorts are under the front passenger seat, behind rear seat back, and C-pillar. After repairing any shorts, or if no shorts are found, remove the keypad to check the part number. If the engineering part number stamped on the part is 1F2T-14A626-ADW, replace the keypad with 1F2Z-14A626-AAA, or the latest level part available. The latest level part will have engineering prefix 4W1T or higher stamped on the new part.
2003 Lincoln Town Car
Signature with Limited Edition package
Old 10-25-2015, 07:20 PM
Coruptor Coruptor is offline
Thank you, i found my code written in black marker on the left deck lid bracket, facing the rear, very faded. but there.
Old 10-25-2015, 11:31 PM
Nice! Nearly 10 years this thread has been lying here waiting to help somebody. The internet is a wonderful thing.
I'm still loving my 03. I've changed the oil a bunch of times and bought a set of tires since then. (more or less) And I still get compliments.
Old 10-29-2015, 04:19 PM
All2kool's Avatar
All2kool All2kool is offline
Somebody wrote it there as that was not done at the factory.
