Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 02-20-2006, 09:14 AM
Ryuichi Ryuichi is offline
Cruise control doesn't do anything
96 Concorde Lxi
It started out that when I tried to use cruise control, it would kick on, and then would usually randomly shut off after anywhere from 1 - 30 minutes, but on occasion it would decide to stay on. Now, however, the button doesn't do anything, and the light doesn't even come on.
I found the electrical connectors by the firewall, but haven't had a chance to unplug them/clean the contacts. I'm looking for any and all possibilities for things to try when I decide to brave the cold again (it's ~15F outside, which is colder than it usually gets all year.)
Any ideas? Other than that, the car runs fine... except for chugging a bit of oil.
Also, what kind of oil does a 96 concorde lxi take? I misplaced my manual somewhere at home, and I'm at school now. The oil's at MIN now, and I want to top it off.
Old 03-01-2006, 10:43 AM
Re: Cruise control doesn't do anything
Update: I was dumb and didn't do the key thing right, so I now have the error code. It's 34: open or short to the cruise solenoid. I pulled the wires out of the servo itself, and tried plugging/unplugging a few times and nothing. It doesn't look like that wire goes through the main bulkhead connector, so I'm a bit stumped.
Old 03-01-2006, 12:42 PM
AWP9521 AWP9521 is offline
I was going to say check out the switches at the steering wheel or maybe the clockspring went bad until you said it threw the 34 code, sounds like the Cruise servo or the dump solenoid went bad, (Both are in the servo unit) make sure there is vacuum to the servo first by unhooking the hose with the engine running and check for vacuum, if present then try replacing the servo, they should be relatively inexpensive at a wrecking yard providing they didn't cut the cabling.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 03-02-2006, 03:14 AM
Does the vacuum hose just pull off? The Haynes manual doesn't say much about the cruise control.
Old 04-24-2006, 10:20 PM
For a while, the cruise would turn on if the steering wheel was turned to the right, and turn off when I turned it left. Any idea where I'd be losing the connection?
