Just replaced everything in the front brakes and bled them, however they feel a little spongy still. The pedal has some play in it before the brakes start to grab. The car stops good, but I want to be safe, after all it's the brakes. Anyone have any good tricks on how to bleed the brakes.
93 Escort 1.9L LX Hatchback - 285k miles 04 Explorer Sport Trac - 45K Miles Funny & Offensive TShirts WWW.AMERICASFUNNIESTTSHIRTS.COM Free Resource's & Advertising @ WWW.LASTCORP.COM |
Re: Help with Bleeding the brakes
Bleed right rear, then left rear, then right front, then left front. That way you're working the air bubbles closer to the master. If you bled the short lines first, then air bubbles probably traveled into the long rear lines. You just replaced calipers, right? No master cylinder?
Yes, just the calipers. no master cylinder. This is exactly how I did it, using the old tube from the bleeder valve into a container of Brake fluid. One person job and it worked perfect. Thanks!
if have 2 people, do u need tube on a container still?
Do we need to bleed it every time we change the brakes? I need to do my rear ones, and I'd rather not. Front don't need it, and the back ones are a big enough job anyway.
Current Vehicles: 2008 Nissan Altima ~ 115k miles 2010 Nissan Maxima ~ 74k miles 2007 Toyota Sienna LE ~ 145K miles Goners 1997 Ford Escort ~145k miles (SOLD) 2013 Kawasaki Ninja 300 ~13k (SOLD) 1983 Honda Magna V45 ~13k (SOLD) 2004 Mazdaspeed Miata ~90k (SOLD) 2001 Ford Mustang GT ~86K (SOLD) 2007 Suzuki Boulevard M50 ~12k (SOLD) 2001 Nissan Maxima - (TOTALLED) 2001 Oldsmobile Intrigue (SOLD) 1991 Nissan Maxima (TOTALLED) 1989 Pontiac Grand Am (SOLD) |
Yes, you should bleed the brakes. Bleeding the brakes is part of the job. Brake fluid attracts moisture and should be changed every couple of years. Bleeding the brakes just takes a few minutes and is the easiest part of the job. I don't understand why you would want to skip that step.
I have never found anything difficult about bleeding ABS brakes. |
No need to bleed brakes if you are just changing pads or shoes!
incase you don't already know, your going need a C-clamp to squeeze the brake caliper in, so that the new thicker pads can be installed.
